[Qgis-developer] How to modify QGIS UI at start?
Nathan Woodrow madmanwoo at gmail.com
Fri May 3 06:29:19 PDT 2013
David,
Can you paste the command line call you are using.
--configpath does work, I use it one of my projects here
https://github.com/NathanW2/qmap/blob/master/src/loader_src/qmap.bat
- Nathan
On Fri, May 3, 2013 at 11:15 PM, db-esm <david at esmarkets.com> wrote:
> When I try to use "code" or "customizationfile" as a command line option, I
> get an error message like:
> "The layer C:\Users\Public\ThumbImage\--code is not a valid layer and cant
> not be added to the map"
> The "--configpath" option doesn't result in an error message, but has no
> effect: the UI settings are still read from (and written to) the Windows
> registry.
> Perhaps on Windows, QSettings always uses the registry now?
> David
> Nathan Woodrow wrote
> > Yes it works on all platforms.
> > - Nathan
> > On Thu, May 2, 2013 at 11:31 PM, db-esm <
> > david@
> > > wrote:
> >> Does this work on Windows?
> >> Sorry, I should have mentioned from the beginning that we're on Windows.
> >> David
> >> > If you save the ini file out and edit it by hand.  It's just a bunch
> of
> >> > true and false switches.  You can can then load QGIS using the
> >> > --customizationfile your.ini option and it will change the UI on load
> >> > QGIS can also take a --code yourpythonfile.py that will run after the
> >> > project is loaded.
> >> > - Nathan
> >> > On Thu, May 2, 2013 at 5:22 PM, Marco Bernasocchi
> >> > marco@
> >> > >wrote:
> >> >> On 05/01/2013 08:19 PM, db-esm wrote:
> >> >>> Yes, but we need to have this happen automatically without users
> >> having
> >> >>> to do
> >> >>> it manually.
> >> >>>  IIRC you can deploy a customization.ini file, it will be read at
> >> >>> startup
> >> >> ciao
> >> >>> View this message in context: http://osgeo-org.1560.x6.**
> nabble.com/How-to-modify-QGIS-**UI-at-start-tp5050659p5050686.**html<http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5050686.html&gt
> >> >>> Sent from the Quantum GIS - Developer mailing list archive at
> >> >>> Nabble.com.
> >> >>> ______________________________**_________________
> >> >>> Qgis-developer mailing list
> >> > Qgis-developer at .osgeo
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer&gt
> >> >> Marco Bernasocchi
> >> >> http://opengis.ch
> >> > _______________________________________________
> http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5050959.html
> Nabble.com.
> http://osgeo-org.1560.x6.nabble.com/How-to-modify-QGIS-UI-at-start-tp5050659p5051179.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130503/4c21f8be/attachment-0001.html>
