[Qgis-developer] Could ubuntugis PPA be a recommended repository for QGIS 2.0 on Ubuntu ?
Jürgen E. Fischer jef at norbit.de
Mon May 6 06:50:30 PDT 2013
Hi Ivan,
On Mon, 06. May 2013 at 14:58:55 +0200, Ivan Mincik wrote:
> I wonder if ubuntugis PPA could be a recommended and only one repository
> for QGIS 2.0 on Ubuntu instead of distribution packaged version and
> package from 'http://qgis.org/debian'.
Recommended: ok.
Only: why?
I don't see the problem with a less intrusive version (ie. qgis on plain
ubuntu) and a more intrusive version (ie. qgis on ubuntugis).
Switching between the same versions from different repositories might be a
problem, but I suppose that doesn't happen often.
Maintaining both versions wasn't a big problem in the past, so I don't expect it
be come one in future.
The packages are only built on release, with the current dependencies at that
point - and only updated, when manually when necessary.  But that also applies
to both repositories.
> What needs to be done ?:
> 1. Fine tuned Debian 'control' file to prevent conflicting installation of
>    packages after upgrading from distribution packages to UbuntuGIS
>    (this is the case for example in GDAL)
0. Report those problems.
> 2. More clearly described relation between ubuntugis-stable and
>    ubuntugis-unstable repositories (when the packages move from unstable to
>    stable ...)
Yes, that would be nice to know - I only upload to ubuntugis-unstable ;)
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
committ(ed|ing) to Quantum GIS                         IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
