[Qgis-developer] many SVG symbols disappeared
Duarte Carreira DCarreira at edia.pt
Tue May 7 01:42:49 PDT 2013
If we can get hold of the old symbology lib than that's fine by me. But please don't make us and others rebuild their entire organization's cartography just because you don't like the symbols.
Thanks,
Duarte
-----Mensagem original-----
De: Tim Sutton [mailto:lists at linfiniti.com]
Enviada: segunda-feira, 6 de Maio de 2013 21:56
Para: Olivier Dalang
Cc: Nathan Woodrow; qgis-developer; Giovanni Manghi; Duarte Carreira
Assunto: Re: [Qgis-developer] many SVG symbols disappeared
Hi
On Mon, May 6, 2013 at 2:31 PM, Olivier Dalang <olivier.dalang at gmail.com> wrote:
> I was asking that question on this thread :
> http://osgeo-org.1560.x6.nabble.com/Ideas-on-the-SVG-symbols-library-t
> d5040508.html#a5046486
> Maybe I didn't emphasize enough on the deletion of symbols...
> IMO, the most elegant solution is to keep only the good-looking
> symbols so we provide a simple and consistent library, and then to
> provide a link on the website to download the unmodified 1.8 symbol
> library in case one needs to keep full backwards compatibility (it's
> quite easy to install : you just have to replace the SVG folder in your installation folder).
> The whole pull request already breaks backwards compatibility with all
> other symbols, since by removing their background, the may become
> unreadable on most of the maps...
> So if the priority is the keep old projects looking the same rather
> than having a clean and consistent library, the best is not to change
> the svg library at all.
> (just as an illustration, do you really think it's pertinent to keep
> this in the library ? :
> https://www.dropbox.com/s/jj9e852r08w5ysp/north-arrow_10_with_map_laye
Yeah that ain't pretty...
Personally I like Oliver's patch and I think we should clean up house for 2.0. Keeping compatibility is useful but most of my project files from 1.8 are already broken to some degree and I would prefer we do all the big changes in 2.0 and then become more conservative in subsequent 2.x releases.
Regards
Tim
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager) ==============================================
Please do not email me off-list with technical support questions. Using the lists will gain more exposure for your issues and the knowledge surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
