[Qgis-developer] Histograms huge
Matthias Kuhn matthias.kuhn at gmx.ch
Tue May 7 02:33:16 PDT 2013
On Tue 07 May 2013 11:03:16 AM CEST, Paolo Cavallini wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 03/05/2013 19:38, Matthias Kuhn ha scritto:
>> Because I was lacking a better idea, I just filled in
>> * the maximum value of any attribute for histograms
> in my case, it selected the attribute with the max value, but it did not autofill the
> max value.
> I think the correct behaviour would be:
> * the user should select the attribute(s) to plot (so this should go to the top of
> the form, as it is now the only thing the user has necessarily to deal with)
> * the max value should be autofilled with the highest value of the variables selected
The problem I see here is, that
a) you don't know when the user finished selecting attributes (unless
he's clicking ok, that's what I do now)
b) if you change the field after every change in the attribute
selection, a manually defined value may be overwritten
The way around this would IMO be a checkbox
[x] Use maximum value
I don't know what the current release plan is (GUI freeze, as fas as I
remember, should already be in place?)
>>> * It would be nice that on reopening the user will find the last used tab, instead of
>>> going back to the first one.
>>> * The default for scale dependent visibility should match those on the General tab
>>> rather than being -1.
>> All done. Thank you for the inputs.
>> I'd be glad if you could give it a short test.
> Done, thanks a lot. Much more usable now, I believe.
> All the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.12 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAlGIw1QACgkQ/NedwLUzIr7JZACggwkumeEhJ3igyjWwAdB0xXyE
> hOIAniMwnT45OF38CIM7Tx6Y60BcwiQS
> =MDnH
> -----END PGP SIGNATURE-----
