[Qgis-developer] Histograms huge
    Matthias Kuhn
    matthias.kuhn at gmx.ch
    Tue May  7 04:21:39 PDT 2013
On Tue 07 May 2013 12:29:02 PM CEST, Paolo Cavallini wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 07/05/2013 11:33, Matthias Kuhn ha scritto:
>>> a) you don't know when the user finished selecting attributes (unless he's clicking
>>> ok, that's what I do now)
>>> b) if you change the field after every change in the attribute selection, a manually
>>> defined value may be overwritten
>>> The way around this would IMO be a checkbox
>>> [x] Use maximum value
> you mean, per attribute (a radio button then)?
> agreed, good idea.
> thanks.
My idea was to replace (or complement) the max value button with a
checkbox. If you check the box, the field gets grayed out and synced to
the max value, whenever
* in case of histogram: the attribute list changes
* in case of circular diagrams: the scale field changes
This way, a user action is required to transfer the control of this
field from user responsibility to software responsibility and the
current state is communicated transparently.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.12 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAlGI124ACgkQ/NedwLUzIr6SpwCeMp2uzbIVI0azTQQVo1PM49cU
> E88AoLXuAklaY/0rKonfKucDtPr7VjZe
> =nTRU
> -----END PGP SIGNATURE-----
