[Qgis-developer] Composer map size and extent
Alexander Bruy alexander.bruy at gmail.com
Wed May 8 00:15:12 PDT 2013
Hi all,
is it possible to change composer map extent (and scale) programmatically without changing its width and height? When using setNewExtent() method width and height of the composer map frame
changed and overlaps with other composer elements, so resulting
image looks differently from template.
Alexander Bruy
