[Qgis-developer] Unit tests
Chris Crook
ccrook at linz.govt.nz
Sun May 19 23:36:49 PDT 2013
Hi Benedict
I put on the delimited text tests, but only have Ubuntu development platform set up at the moment (on which of course they pass!!).
What platform are these results on, and do you have any more details for the delimited text failures?
Thanks
Chris Crook
Message: 1
Date: Sun, 19 May 2013 14:13:51 -0400
From: Benedict Holland <benedict.m.holland at gmail.com>
To: qgis-developer <qgis-developer at lists.osgeo.org>
Subject: [Qgis-developer] Unit tests
Message-ID:
<CAD+mzoyLfmxikvsb-3W3js18fhd2DrrgcNvO9fExXjMU5UjEHA at mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Hi all,
How up to date are the unit tests? I seem to be getting quite a lot of
failures by the look of things but I am not sure if these are up to date or
not. BTW, the program compiles and seems to run so these unit tests might
just be very outdated.
This is my output of make test
Test project /home/ben/git/Quantum-GIS/build
Start 1: qgis_clippertest
Start 52: PyQgsDelimitedTextProvider
52/67 Test #52: PyQgsDelimitedTextProvider ...........***Failed 0.51 sec
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
