[Qgis-developer] QGIS Server - performance issue in master since one week (after df19fe5e04b0c2ae8f1b13000099715559e6bd50 )
kimaidou kimaidou at gmail.com
Wed May 22 09:10:18 PDT 2013
Answers below
2013/5/22 Matthias Kuhn <matthias.kuhn at gmx.ch>
> On top of current master (so checked out most recent commit with bad
> performance):
> git revert df19fe5e04b0c2ae8f1b13000099715559e6bd50
> git revert 35de29df9bea0a8d36d54aec677df054d7cd37ba
Ok. So I reverted these 2 commits. I am now runnin the compilation (it will
last approximatively 10 minutes)
I will tell you if the regression occurs or not after this changes
> One more question: Do you have any plugins running? (Is this even
> supported by server)?
QGIS Server does not support plugins, so I think this won't change anything.
Thanks for your help
Michael
> > <mailto:matthias.kuhn at gmx.ch>>
> >     Hi Michael,
> >     It's probably the commit you identified:
> >     Fix wmsserver: Do not manipulate maplayerregistry directly
> > I think so too.
> >     I'm almost sure if you revert this one and commit
> >     35de29df9bea0a8d36d54aec677df054d7cd37ba it will run fine.
> >     I'll have a look and revert these in case I don't find a solution to
> >     get around this.
> >     As I don't have a mapserver running here, could you assist with
> >     testing
> >     if I have a possible fix ready?
> > Yes, sure I will !
> > I would like to try reverting only this commit, but I will need help
> > here. Your idea is to revert this commit, then checkout into latest
> > today's commit ? Could you help providing relative git commands ?
> > Thanks
> >     Regards,
> >     Matthias
> >     On Mit
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130522/f9732649/attachment.html>
