[Qgis-developer] QGIS Server - GetPrint with a composer containing HTML block causes segfault
kimaidou
kimaidou at gmail.com
Thu May 23 06:00:57 PDT 2013
I report my progress here
I managed to get a PDF via the GetPrint request by following these steps
1/ Create a fake X server
Xvfb :99 -ac -noreset &
2/ Add the option in the fastcgi , for example
FastCgiConfig -idle-timeout 70 -maxClassProcesses 50 -minProcesses 3
-init-start-delay 3 -restart-delay 20 -startDelay 15 -initial-env
DISPLAY=:99 LD_LIBRARY_PATH=/home/kimaidou/src/qgis/build/lib/
3/ Restart Apache
service apache2 restart
After this, I tried the GetPrint request from my QGIS project with a
composer containing a HTML item. The request get a PDF as an answer, but
the HTML item is empty.
I will try with another composer, etc., and report here.
By the way, is there a way to pass an HTML string via a parameter to the
getPrint request for HTML items, as it is possible for text item ? This
would rock !
Michael
2013/5/23 kimaidou <kimaidou at gmail.com>
> Hi Tim and Marco
> I come back to this subject after helping to solve the performance problem
> with Mathias.
> So, I am first runnning my tests on my ubuntu laptop. Since it is my
> computer, it is not ubuntu server but the classical Ubuntu with an X server
> running.
> I tried in my terminal
> echo $DISPLAY
> :0
> So it seems (but I am far from being a X server guru !) that this is the
> DISPLAY value I should pass to QGIS Server.
> This is why I added the following configurartion in my virtual host (and
> in the fastcgi config file):
> In the virtual host
> ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
> <Directory "/usr/lib/cgi-bin">
> AllowOverride None
> Options +ExecCGI -MultiViews FollowSymLinks
> Order allow,deny
> Allow from all
> SetEnv LD_LIBRARY_PATH "/home/kimaidou/src/qgis/build/lib"
> SetEnv DISPLAY :0
> </Directory>
> In /etc/apache2/mods-available/fastcgi.conf
> <IfModule mod_fastcgi.c>
> AddHandler fastcgi-script .fcgi
> #FastCgiWrapper /usr/lib/apache2/suexec
> FastCgiIpcDir /var/lib/apache2/fastcgi
> DISPLAY=:0 -initial-env LD_LIBRARY_PATH=/home/kimaidou/src/qgis/build/lib/
> </IfModule>
> I am pretty confident the default configuration is not used but I doubled
> it just in case
> After restarting my Apache Server, QGIS Server just hangs with the very
> simple URL
> http://localhost/cgi-bin/qgis_mapserv.fcgi
> which should reply with an error in XML format.
> So it seems Apache/QGIServer do not like my DISPLAY parameter.
> Any hint ?
> Would it be simplier to test this in a real server with no existing X
> Server by using Xfvb ?
> Michael
> 2013/5/22 Tim Sutton <lists at linfiniti.com>
>> Hi
>> You might also want to consider using Xfvb as a 'fake' xserver.
>> Regards
>> Tim
>> On Wed, May 22, 2013 at 10:19 AM, kimaidou <kimaidou at gmail.com> wrote:
>> > Thanks for your answer Marco. I will try to use the workaround you
>> described
>> > and report progress here.
>> > Michael
>> > 2013/5/22 Marco Hugentobler <marco.hugentobler at sourcepole.ch>
>> >> Hi Michael
>> >> I also encountered that problem. Unfortunately, it seems that QWebKit
>> >> requires a running x-server. So it won't be possible to use html items
>> in
>> >> server projects (or you can run an x-server and set the DISPLAY
>> variable in
>> >> the fcgi conf).
>> >> Regards,
>> >> Marco
>> >> On 22.05.2013 09:43, kimaidou wrote:
>> >> Hi list
>> >> I have tried it with today's qgis master.
>> >> I have a very simple project with one shapefile containing 3
>> polygones. I
>> >> created a composer with a map. GetPrint request works fine with it. If
>> I add
>> >> an HTML block in the composer (refering to one HTML file or not), the
>> >> getPrint request raises a segfault.
>> >> Apache error log is the well-known :
>> >> "Premature end of script headers: qgis_mapserv2.fcgi"
>> >> By the way, I compiled QGIS with -DCMAKE_BUILD_TYPE=debug , but I do
>> not
>> >> know where I can find complet log for QGIS Server. Is there a file
>> where I
>> >> can get complete log for QGIS Server ?
>> >> I can provide a sample project if needed. I have not found a ticket in
>> the
>> >> hub, so I will fill one, but I would prefer to do so with a
>> self-explaining
>> >> log.
>> >> Michael
>> >> _______________________________________________
>> >> Qgis-developer mailing list
>> >> Qgis-developer at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >> Dr. Marco Hugentobler
>> >> Sourcepole - Linux & Open Source Solutions
>> >> Weberstrasse 5, CH-8004 Zürich, Switzerland
>> >> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> >> Technical Advisor QGIS Project Steering Committee
>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>> * QGIS programming and support services
>> * Mapserver and PostGIS based hosting plans
>> * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130523/a4caa5b1/attachment.html>
