[Qgis-developer] Layers rendering order swapped (behavior change)
Sandro Santilli strk at keybit.net
Thu May 23 13:20:39 PDT 2013
I saved a simple project with 3 layers from 1.8.0.
Opening it with current master (commit:83445af) renders those
3 layers upside down (layer on top in the layer manager is
rendered at the bottom in the map canvas).
Moving layers around confirms the behavior: you have to move
point layers at the bottom in order for them to NOT be covered
by lineal layers.
Is this intentional ?
--strk;
