[Qgis-developer] Layers rendering order swapped (behavior change)
Sandro Santilli
strk at keybit.net
Thu May 23 13:33:50 PDT 2013
On Thu, May 23, 2013 at 10:23:23PM +0200, Andreas Neumann wrote:
> Hi Strk,
> is the layer ordering panel active and controlling the layer rendering
> order or is the layer panel controling the layer rendering order?
Moving layers in the layer panel changes the rendering order.
I do not see a layer ordering panel.
Right-click menu shows "Update drawing order" is unchecked,
if I check it things work as they used to (top layer is rendered on top);
unchecking it again that order is swapped.
Activating the layer ordering panel indeed shows that items in
that panel are always following changes in the layer panel, so
to be always in the reverse order of the latter. Funny :)
--strk;
> Andreas
> Am 23.05.2013 22:20, schrieb Sandro Santilli:
> > I saved a simple project with 3 layers from 1.8.0.
> > Opening it with current master (commit:83445af) renders those
> > 3 layers upside down (layer on top in the layer manager is
> > rendered at the bottom in the map canvas).
> > Moving layers around confirms the behavior: you have to move
> > point layers at the bottom in order for them to NOT be covered
> > by lineal layers.
> > Is this intentional ?
> > --strk;
