[Qgis-developer] [Qgis-user] New Icons - difficult to "read"
Duarte Carreira DCarreira at edia.pt
Fri May 24 03:15:10 PDT 2013
I would like to ask the "powers that be" to keep the old and trusted icons. They never failed me and the gui is quite uplifting. The new set may be technically better but is not as friendly to users.
Please keep both.
Duarte
De: Jonathan Moules [mailto:jonathanmoules at warwickshire.gov.uk]
Enviada: sexta-feira, 24 de Maio de 2013 09:59
Para: skampus
Cc: qgis-user at lists.osgeo.org; qgis-developer at lists.osgeo.org
Assunto: Re: [Qgis-user] [Qgis-developer] New Icons - difficult to "read"
+1
i.e. The difference between the "Add PostGIS layers" and "Add SpatiaLite layers" is that one has a regular cylinder and the other has a fat-waisted hour-glass cylinder - about 20-30 pixels are different in an icon that's got 1024 pixels! I have to look at them in detail to see the differences. And there's still MSSQL and Oracle icons to be created in the new schema which using this system will only confuse things more.
Don't get me wrong, I like the style of the new icons, but they're really hard to visually differentiate.
I did a quick google and came across this:
http://turbomilk.com/blog/cookbook/icon_design/10_mistakes_in_icon_design/
The QGIS icons do all of the top three things.
Jonathan
On 24 May 2013 09:27, skampus <stefano.campus at regione.piemonte.it<mailto:stefano.campus at regione.piemonte.it>> wrote:
that could be a useful option.
sincerely, from my point of view, many icons are
unreadable/undistinguishable so i click them correctly only because now i
remberer relative position
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-Qgis-user-New-Icons-difficult-to-read-tp5055427p5055467.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-developer
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130524/3eda30cd/attachment.html>
