[Qgis-developer] the new Plugin Manager
Borys Jurgiel lists at borysjurgiel.pl
Mon May 27 05:23:17 PDT 2013
Hi All,
The new manager is ready. Here is a screenshot for impatient ones :)
http://tmp.borysjurgiel.pl/manager4.png
The code is in a branch "newmanager":
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771
As it affects a number of classes, please review the architecture summary
below and if there is no veto, it's ready to be merged to master. Otherewise I'll
make requested changes before merging.
*QgsPluginItem*
Removed. It only used in the old manager and wasn't usefull anymore.
*QgsDetailedItemData, QgsDetailedItemDelegate and QgsDetailedItemWidget*
Untouched. It was used in the old manager and Grass Plugin, now it's used
exclusively by Grass Plugin.
*QgsPluginMedatadata*
Untouched, however I propose to rename it to QgsPluginItem or QgsPluginRegistryItem
for consistency. It's only used in QgsPluginRegistry and it mainly conatains
pointers to loaded plugins instances, while its name may imply a rich metadata
map. If some day during QGIS 2.x lifetime the Manager will need a separate class
for storing rich metadata (now QMap is enough), and it would be nice to use this name.
*QgsPluginRegistry*
Info: This class is a registry for instances of lodaded plugins. It has nothing to to
with metadata and it works independently from the manager, just by restoring
session plugins from QSettings. Manager only calls its method to load and unload plugins.
Small change: as it already had methods loadCppPlugin() and loadPythonPlugin(),
I've added also unloadCppPlugin() and unloadPythonPlugin() too keep the
loading/unloading stuff in one place.
Diff:
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgspluginregistry.h
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgspluginregistry.cpp
*QgsPluginManager*
Completely rewritten and moved to src/app/pluginmanager/ subdirectory
class for the dialog window. Important facts:
1) It keeps plugin metadata registry just in nested QMap:
QMap< QString, QMap<QString,QString> >   mPlugins;
where the first key is library/module basename, and the second one is attribute
name. There was no need to create a separate class for storing metadata,
however, some day it may become convinient to create a class called QgsPluginMedatadata.
For this reason I propose to rename the current QgsPluginMedatadata
(what actually has nothing to do with metadata) before releasing QGIS 2.0.
The list of used attributes is provided in the "metadata" file and it's an unification
of existing fields from repository xml, metadata.txt, the old installer and c++ plugins.
QgsPluginManager populates this field (let's call it metadata registry) with
c++ plugins when the window is opened. On the contrary, Python plugins
are handled on Python's side and they are appended to mPlugins by API.
2) The plugin list view uses QStandardItemModel populated from mPlugins
and also QgsPluginSortFilterProxyModel for filtering and sorting.
3) The html metadata browser is quite simple, and we can extend it in QGIS 2.1.
For example, some tags can be clickable and set a new filter (filter by clicked
author/tag/status). Also the separate buttons Install/Uninstall can be
implemented by html "buttonsm", and the popup dialog with installation progress
can be replaced by animated image (this way we don't freeze the gui when installing).
Code:
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginmanager.h
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginmanager.cpp
*QgsPluginSortFilterProxyModel*
New class: just a sort-filter proxy for the metadata. Filtering is done by status
in the left list as well as name/description/tags/author in the filter input line.
Sorting is done by rightclicking on the list. Foltering and sorting is based
on a few user data roles. I tried to read necessary data from mPlugins everytime,
but it affected the performance too much.
Code:
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginsortfilterproxymodel.h
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgspluginsortfilterproxymodel.cpp
*QgsAppPluginManagerInterface, QgsPluginManagerInterface and SIP binding*
New classes: just the interface to QgsPluginManager. Is's exactly based
on the existing Qgs(App)LegendInterface
Code:
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/python/gui/qgspluginmanagerinterface.sip
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/gui/qgspluginmanagerinterface.h
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/gui/qgspluginmanagerinterface.cpp
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgsapppluginmanagerinterface.h
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/entry/src/app/pluginmanager/qgsapppluginmanagerinterface.cpp
QgisApp
Small change: initialize the QgsPluginManager and Python module
pyplugin_installer in the constructor. Only open the QgsPluginManager window
when called from the main menu.
Diff:
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisapp.h
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisapp.cpp
QgisAppInterface and QgisInterface and SIP binding
Small change: instantiate Qgs(App)PluginManagerInterface
exactly the same way as Qgs(App)LegendInterface
Diff:
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisappinterface.h
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/diff/src/app/qgisappinterface.cpp
pyplugin_installer Python module
New python module in python/pyplugin_installer. It contains just slightly refactored
code of the old plugin_installer plugin and provides backend for handling Python
plugis, e.g.: fetching remote repositories, loading installed plugin metadata, finding
upgradeable plugins, (un)installing python plugins etc. It's methods are called from
QgsPluginManager and it calls QgsPluginManager methods via QgsPluginManagerInterface.
Code:
http://hub.qgis.org/projects/quantum-gis/repository/revisions/5ee09d362148c411047a0fc7bc22679d9989f771/show/python/pyplugin_installer
