[Qgis-developer] QGIS Server - GetPrint request does not respect text boxes size and position if dynamic content passed
rldhont rldhont at gmail.com
Mon May 27 13:23:08 PDT 2013
Hi Marco and other devs,
In src/mapserver/qgsconfigparser.cpp:530 we can read :
   //replace label text
   foreach ( QgsComposerLabel *currentLabel, composerLabels )
     QString title = parameterMap.value( currentLabel->id().toUpper() );
     if ( title.isEmpty() )
       //remove exported labels not referenced in the request
       if ( !currentLabel->id().isEmpty() )
         c->removeItem( currentLabel );
         delete currentLabel;
       continue;
     currentLabel->setText( title );
     currentLabel->adjustSizeToText();
This code is used to draw composer label with value defined by the QGIS
WMS Server Request GetPrint.
The bug defined in the issues #7894 http://hub.qgis.org/issues/7894 is
probably du to the method adjustSizeToText()
Someone can confim it ?
Question for Marco, Why removed label, if the request doesn't define a
value ? Why not used the default value ?
Regards,
René-Luc D'Hont
3Liz
