[Qgis-developer] Python error in master
Larry Shaffer
larrys at dakotacarto.com
Tue May 28 09:39:22 PDT 2013
Hi Paolo,
On Tue, May 28, 2013 at 10:33 AM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi Paolo,
> On Mon, May 27, 2013 at 9:49 AM, Paolo Cavallini <cavallini at faunalia.it>wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Il 27/05/2013 16:04, Paolo Cavallini ha scritto:
>> > RuntimeError: the sip module implements API v8.0 to v8.1 but the
>> qgis.core module
>> > requires API v9.2
>> > Packages from debian-nightly, sid.
>> > Anything wrong?
>> confirmed on another machine: am I the only one?
> Something similar happened to me last week, just after I updated my
> version of sip (manually compiled). Guessing here, but it seems that a
> change in sip version does not trigger any rebuilds of already-built QGIS
> Python modules during subsequent compiling of source code.
> However, your error seems to be the reverse of that, almost like an older
> sip version is still installed somewhere on your machine, then found during
> runtime, while the built software referenced the newer version. This may be
> because during compilation, your environment is referencing a different
> version of Python (i.e. newer site-packages/sip.so) or a virtual env, than
> the one used during runtime of the app, which has an older sip.so installed.
I just noticed you mentioned 'Packages from debian-nightly, sid,' which I
assume means for QGIS. If the sip.so module is not part of those packages
(I would suspect not), maybe just upgrading your local sip install will fix
the issue.
Larry
> I 'fixed' my sip compile error by deleting my build directory's contents
> and doing a fresh CMake configure and build.
> Regards,
> Larry
>> all the best.
>> Paolo Cavallini - Faunalia
>> www.faunalia.eu
>> Full contact details at www.faunalia.eu/pc
>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.12 (GNU/Linux)
>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
>> iEYEARECAAYFAlGjgJcACgkQ/NedwLUzIr6/JACgmIaMqCp4HIyCbXN6U68ddX5p
>> FW4AmQG0X0gAcnekbgmjqaW9Vf3MwF5C
>> =Hcms
>> -----END PGP SIGNATURE-----
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130528/b6a54702/attachment.html>
