[Qgis-developer] Updating core plugins
Borys Jurgiel lists at borysjurgiel.pl
Tue May 28 15:16:01 PDT 2013
Dnia poniedziałek, 27 maja 2013 o 20:44:01 Victor Olaya napisał(a):
> > Yes, non-core plugin overrides the core one (just because of the Python
> > path order), so the only thing you can do is to make the core SEXTANTE
> > version higher - at least QGIS will warn about the override and suggest
> > manual uninstall.
> Borys, I think this is not working. I have received reports of people
> having SEXTANTE 1.0.9 interfering with the core 1.1 version, and I
> tested it myself. If you have a plugin in .qgis2, it will override the
> core one (as you mention), but no warning is produced.
You're right, there is a bug. I'll fix it next week.
