[Qgis-developer] TauDEM problem
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Wed May 29 09:16:21 PDT 2013
Could you report the error or warning messages you get in SEXTANTE history
and log?
Also, does  pit remove command work under normal shell/command prompt?
Cheers
Saber
-----Original Message-----
[mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of marlon.calispa
Sent: 29 May 2013 17:11
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] TauDEM problem
Alexander:
I realized that tauDEM is not included in the sextante toolbox, I think it
could be a common mistake between new QGIS users like me.
I have installed the tauDEM as showed in several pages (including the MPICH2
service, and the TauDEM 5.0.6 routines, and I have directioned in the
sextante configuration options).
As you recommend I tried to run the algorithm from the python console, but
there is no result, I mean, the process seems to start and my QGIS start
processing but never ends ( I have waited for more than 4 hours) with a
small raster and the pit remove algorithm.
There is any other consideration Im omitting?
Thanks and apologies for my simple questions.
View this message in context:
http://osgeo-org.1560.x6.nabble.com/TauDEM-problem-tp5056516p5056799.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
