[Qgis-developer] TauDEM problem
marlon.calispa marloncalispa at yahoo.es
Wed May 29 13:08:32 PDT 2013
Alexander.
Thanks for your advice.
I have tried to run TauDEM from the cmd, and I discovered a lot of missing
things....
It seems that TauDEM didnt run because the MPICH2 was wrong installed (I
mean i consider a little difficult to install without mistakes at the first
time), I reinstalled everything and now the routines in the sextante are
running normally, I will perform some tests to check if it is true.
Regards.
View this message in context: http://osgeo-org.1560.x6.nabble.com/TauDEM-problem-tp5056516p5056834.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
