[Qgis-developer] First time compilation
Joao Machiana joaomachiana at gmail.com
Thu May 30 08:12:35 PDT 2013
Hi all
I'm about to start using QGIS for some projects of my organization, but I'm
facing some problems (maybe they're not a problem at all)
I've set up the QGIS development platform.
I've downloaded and installed QGIS Lisboa apart. (not from OSGeo4W)
I've followed the "qgis-1.6.0_coding-compilation_guide" (line by line) and
I've been able to configure and generate the qgis source code to be
compiled.
I'm using cmake 2.8, and Visual Studio 2010 express edition
I could sucessfully compile the qgis source code.
But right now I want to compile the files in the code examples, and every
time I click configure on cmake, I receive the error:
CMake Error at cmake_find_rules/FindQGIS.cmake:135 (MESSAGE):
Could not find QGIS
Call Stack (most recent call first):
CMakeLists.txt:6 (FIND_PACKAGE)
I've tried change the paths in the file FindQGIS.cmake, but with resulting
in failure.
This may be a dumb question, but I'm stuck on it for two days.
Thanks in advance for anyhelp.
I've attached the FindQGIS.cmake file
*João X. Machiana*
Systems Analyst and Programmer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130530/33f6b37e/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130530/33f6b37e/attachment.obj>
