[Qgis-developer] Print composer item resizing broken?
Andreas Neumann a.neumann at carto.net
Mon Nov 11 06:44:07 PST 2013
In the current master I cannot resize items interactively in the print
composer. It reacts to resizing, but after I release the mouse button
the width or height of the item jumps back to the original width/height.
Resizing through the "Position and width" settings in the item
properties panel seems to work.
I created a new issue: http://hub.qgis.org/issues/9044
On Windows I noticed that many shortcuts are not available: e.g. delete
(del), paste in place (ctrl-shift-v), undo (ctrl-z), select all
(ctrl-a). Somehow they are not assigned anymore? On Ubuntu they are
still correctly assigned.
Thanks,
Andreas
