[Qgis-developer] Bug with avoid intersection - willing to fund fix
George Silva georger.silva at gmail.com
Thu Nov 14 03:17:56 PST 2013
I already asked a few devs without response.
Ive even dug under the cpp hood to see if I could find somethimg
interesting, and I did, but Im not sure on how to resolve the issue, since
cpp is kinda of  a black art for me :-)
Devs around the world! How much it will cost to fix this bug?
Em 14/11/2013 07:53, "Andreas Neumann" <a.neumann at carto.net> escreveu:
> Hi,
> So if there is so much interest in having this issue fixed I assume that
> there would be plenty out there who would fund the fix!
> The fix won't happen if noone pays for it - just complaining about this
> does not help.
> Get an estimate from some developer (e.g. Sandro Santilli oder
> Sourcepole) to know how much it would cost to fix.
> As much as I like GRASS - and it is very good to know that this
> workaround exists (thanks Stefan for mentioning it!) - I don't think it
> is reasonable to ask people to go through GRASS to get proper data out
> of their QGIS digitized data set.
> Who will take the lead to ask a developer?
> Andreas
> Am 14.11.2013 10:40, schrieb Blumentrath, Stefan:
> > Hi George
> > I had a lot of trouble with those issues too, and I would really love to
> see them fixed. In other words, I agree with Giovanni that these are pretty
> important bugs for many and not really uncommon digitization use-cases and
> would support his categorization as blocker...
> > However, my current workaround is to ignore the untidiness in the
> topology at first and then send the vector dataset through GRASS which is
> (at least for not too big datasets) quite convenient using the
> Sextante/Processing framework (see also discussion here):
> http://osgeo-org.1560.x6.nabble.com/Running-v-clean-on-a-QGIS-vector-layer-Polygon-through-Sextante-td5050418.html
> > Cheers
> > Stefan
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131114/fdfc95be/attachment.html>
