[Qgis-developer] Multi threading and background processing
Tim Sutton lists at linfiniti.com
Fri Nov 22 13:16:21 PST 2013
Hi
On Fri, Nov 22, 2013 at 7:52 PM, Tom Moore <moortom at gmail.com> wrote:
> Hi Martin
> How does one go about distributing an architecture dependent plugin?  I am
> expecting to be developing mine for the windows 64-bit environment.  I wont
> have the facilities to prepare packages for other environments, but of
> course others can take the source code and do what they want.
The most common way of doing this is to get it into the core distribution
of QGIS but that requires:
* the plugin to have a general usefulness to a wide range of users
* and undertaking that the author will continue to maintain it.
If that is not an option, rolling your own QGIS package with a build of
your plugin is another common way of doing it. See [1] for notes on how to
do that.
The last option would be to prepare a dll / so for each platform you wish
to support and create an installer to copy it into the QGIS plugins
directory.
Regards
Tim
[1]
http://linfiniti.com/2011/05/building-custom-qgis-installers-for-windows/
> Can I set up a package that windows 64 users can download and click to
> install?  Will I need to set up my own repository for this purpose?
> Thx,
> Tom
> On Fri, Nov 22, 2013 at 2:33 AM, Martin Dobias <wonder.sk at gmail.com>wrote:
>> On Thu, Nov 21, 2013 at 6:00 AM, Tom Moore <moortom at gmail.com> wrote:
>> > As you can imagine from my newbie questions I'm not a python guy.
>>  While I
>> > really like a lot of the modern mechanisms in python I have never been
>> able
>> > to look at a python script without being puzzled by the retro/hipster
>> nature
>> > of using whitespace as syntax.  As someone who once lined up fortran
>> > statements on punch cards you will have to pry whitespace indifferent
>> > languages from my cold hunt-n-peck fingers. Anyway, I'm expecting to use
>> > python for the ui and glue code, and do all of the number crunching in
>> a C
>> > module.  Horses for courses eh?
>> Let me note one more thing here: if you think of writing number
>> crunching in C, things will get more complicated: you will need to
>> compile and ship the binaries somehow - the plugin repository does not
>> accept plugins with architecture dependent binaries. Maybe try to have
>> a look at numpy module, it's fairly common for fast array/matrix
>> operations in python.
>> Martin
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131122/c0ed0835/attachment.html>
