[Qgis-developer] qgis master compile error on ubuntu 10.04
Marco Bernasocchi marco at bernawebdesign.ch
Thu Oct 3 08:04:41 PDT 2013
yes, that is because each run you pass a sip error and the generated file
is still partly done. eventually you generate enough times and the
compilation goes through. or something like that.
Marco Bernasocchi (mobile)
http://opengis.ch
On 3 Oct 2013 16:58, "Ziegler Stefan" <Stefan.Ziegler at bd.so.ch> wrote:
>  Yes. Some sip version problem?****
> I can run make four times with errors and the fifth time it compiles
> without errors. But then I get an error on qgis startup that pyqgis will be
> disabled.****
> Regards****
> Stefan ****
> *Von:* Marco Bernasocchi [mailto:marco at bernawebdesign.ch]
> *Gesendet:* Donnerstag, 3. Oktober 2013 16:54
> *An:* Ziegler Stefan
> *Cc:* qgis-developer
> *Betreff:* Re: [Qgis-developer] qgis master compile error on ubuntu 10.04*
> thats all you get as error? ciao****
> http://opengis.ch****
> On 3 Oct 2013 15:48, "Ziegler Stefan" <Stefan.Ziegler at bd.so.ch> wrote:****
> Hi
> Now I get some errors in the gui part:
> [ 55%] Generating gui/sipguipart0.cpp, gui/sipguipart1.cpp,
> gui/sipguipart2.cpp, gui/sipguipart3.cpp
> sip: /home/stefan/Develop/src/qgis_master/python/gui/gui.sip:1: syntax
> error
> make[2]: *** [python/gui/sipguipart0.cpp] Error 1
> make[1]: *** [python/CMakeFiles/python_module_qgis_gui.dir/all] Error 2
> make[1]: *** Waiting for unfinished jobs....
> [ 56%] Built target gpsimporterplugin
> [ 56%] Built target topolplugin
> [ 56%] Built target heatmapplugin
> [ 57%] Built target spitplugin
> [ 60%] Built target georefplugin
> Regards
> Stefan
> > -----Ursprüngliche Nachricht-----
> > Von: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-
> > bounces at lists.osgeo.org] Im Auftrag von Ziegler Stefan
> > Gesendet: Donnerstag, 3. Oktober 2013 10:14
> > An: qgis-developer at lists.osgeo.org
> > Betreff: [Qgis-developer] qgis master compile error on ubuntu 10.04
> > Hi
> > I get an compile error on Ubuntu 10.04:
> > [ 31%] Generating analysis/network/sipnetworkanalysispart0.cpp,
> > analysis/network/sipnetworkanalysispart1.cpp,
> > analysis/network/sipnetworkanalysispart2.cpp,
> > analysis/network/sipnetworkanalysispart3.cpp
> > [ 31%] sip: /home/stefan/Develop/src/qgis_master/python/core/core.sip:1:
> syntax
> > error
> > sip:
> /home/stefan/Develop/src/qgis_master/python/analysis/network/networkanalysis.sip:1
> > : syntax error
> > make[2]: *** [python/core/sipcorepart0.cpp] Error 1
> > make[1]: *** [python/CMakeFiles/python_module_qgis_core.dir/all] Error 2
> > make[2]: *** [python/analysis/network/sipnetworkanalysispart0.cpp] Error
> 1
> > make[1]: ***
> [python/CMakeFiles/python_module_qgis_networkanalysis.dir/all] Error 2
> > Should the master still be compilable on 10.04?
> > Regards
> > Stefan
> > Freundliche Grüsse
> > Stefan Ziegler
> > Leiter amtliche Vermessung
> > Amt für Geoinformation
> > Amtliche Vermessung
> > Rötistrasse 4
> > 4500 Solothurn
> > Telefon +41 32 627 75 96
> > Telefax +41 32 627 75 98
> > stefan.ziegler at bd.so.ch
> > http://www.so.ch
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> http://lists.osgeo.org/mailman/listinfo/qgis-developer****
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131003/bdc30c46/attachment.html>
