[Qgis-developer] Testing infrastructure (was: QGIS 2 64bits, is it stable ?)
Jürgen E. Fischer jef at norbit.de
Fri Oct 4 11:03:44 PDT 2013
Hi Sandro,
On Fri, 04. Oct 2013 at 17:50:05 +0200, Sandro Santilli wrote:
> On Fri, Oct 04, 2013 at 04:19:38PM +0200, Paolo Cavallini wrote:
> > AFAIK the infrastructure is already in place and running.
> No reference ?
The nightly builds run tests.  And AFAIK http://jenkins.linfiniti.com/job/QGIS/
builds QGIS and runs tests after each commit.
> Any page reporting test run status?
In jenkins and for the nightlies on:
http://dash.orfeo-toolbox.org/index.php?project=QGIS
We might move that to our new server at some point.
> All I could find on the website is this interesting page:
> http://hub.qgis.org/projects/quantum-gis/wiki/Developers_Manual#Unit-Testing
> "As of November 2007 we require all new features going into trunk to be
>  accompanied with a unit test"
> Is the document still valid ?
Never heard of that - or successfully repressed it.
> Any page reporting test run status ?
s.a.
> PS: "make check" output against * master 6d5cf6f :
>  82% tests passed, 14 tests failed out of 78
>  Total Test time (real) = 471.88 sec
>  The following tests FAILED:
>           4 - qgis_diagramtest (Failed)
>          14 - qgis_rendererstest (Failed)
>          25 - qgis_composermaptest (Failed)
>          30 - qgis_stylev2test (Failed)
>          31 - qgis_composerhtmltest (Failed)
>          33 - qgis_composerscalebartest (OTHER_FAULT)
>          45 - qgis_wcsprovidertest (Failed)
>          51 - PyQgsVectorLayer (Failed)
>          52 - PyQgsRasterLayer (Failed)
>          56 - PyQgsDelimitedTextProvider (Failed)
>          64 - PyQgsComposerMap (Failed)
>          72 - PyQgsPalLabelingBase (Failed)
>          73 - PyQgsPalLabelingCanvas (Failed)
>          78 - PyQgsAppStartup (Failed)
And most of these tests are not really freshly failing (see dash above).
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)                                   IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
