[Qgis-developer] Reliable way to determine a groupIndex in the legend tree
Vincent Schut schut at sarvision.nl
Fri Oct 11 04:35:44 PDT 2013
On 10/11/13 11:48, Sandro Santilli wrote:
> On Fri, Oct 11, 2013 at 09:33:05AM +0000, Andreas Neumann wrote:
>> Am 11.10.2013 09:22, schrieb Sandro Santilli:
>>> On Fri, Oct 11, 2013 at 09:13:03AM +0000, Duarte Carreira wrote:
>>>> The group checkbox, imho, should *not always* switch children on/off. You should have a modifier to get this as a secondary behavior, like pressing the ctrl key when (un)checking the group checkbox. The primary behavior of the group switch should be to make the children invisible or visible, regardless of the children's visibility being on or off.
>>>> In the primary behavior when the parent is turned OFF, the children are not drawn but retain their checked or uncheck status.
>>>> If you use the secondary behavior then unchecking the parent will uncheck the children. Same would apply when checking the parent on.
>>> Agreed, sounds like a sensible behavior to me.
>> Yes, a sensible behavior.
>> But there is still use-case for the radio-button like behaviour. Imagine
>> having a group with a series of orthoimages of different years and you
>> quickly want to see each year. In this case, the radio-button behaviour
>> would save you one click. So I don't think that this contradicts the
>> other proposal listed above here.
> Maybe this could be obtained with secondary behavior (SHIFT-click) on layers,
> but it sounds like something that easily becomes confusing (conflicting
> with radio-on-groups, undefined behavior for unchecking etc.).
switching between several raster layers is exactly the main (only) use I
have for this, and as we are mainly doing remote sensing stuff here,
including lots of time series, it is something I really frequently miss.
(Practical example: you have several Landsat rasters from different
times for the same area, all of them have clouds but not in the same
place. By switching between layers, you can easily get a 'cloudfree'
view of the entire area.)
IMHO 'undefined behavior for unchecking' should not be a problem;
usually unchecking simply is disabled for radio groups. I do not know
any UI with radio groups where you can uncheck a selected item by
clicking it again... I think having it as a secondary behaviour is just
confusing. I'd rather see groups have a 'selection type' property, which
defines the selection behaviour within that group (and on that level
only). Could you explain what you mean with 'conflicting with
radio-on-groups' (what are 'radio-on-groups')?
Vincent.
> --strk;
> Qgis-developer mailing list
