[Qgis-developer] Installing Processing problems
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Thu Oct 17 09:26:32 PDT 2013
Hi Paolo,
According to this just-closed ticket, I think (some of?) this stuff has
been resolved in future standalone builds:
http://hub.qgis.org/issues/8627#change-45754
Jonathan
On 17 October 2013 17:22, Paolo Cavallini <cavallini at faunalia.it> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all.
> I'm struggling to set up Processing, with saga, otb, and grass, on several
> machines,
> and I'm encountering a series of issues:
> * on Win, I had to install osgeo4w 32 bit to have OTB; this resulted in a
> series of
> problems in autoconfig of Processing, solved by removing the standalone,
> the registry
> keys, and activating the saga 2.0.8 compatibility option
> * on osx, grass is not found, even if the path seems correct
> * on Ubuntu 13.04, running grass from processing freezes QGIS
> * on Debian Wheezy saga is not available.
> I think we still have something to improve to make life easier for our GIS
> analysts.
> Any hint welcome, available for testing.
> Thanks.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.15 (GNU/Linux)
> Comment: Using GnuPG with Icedove - http://www.enigmail.net/
> iEYEARECAAYFAlJgDtcACgkQ/NedwLUzIr5VQQCfeOG08RUZYjgJtRE6uTszP8Bn
> hbIAniTN/dFWtCQOSTQZPFmZnRlR0pB3
> =RqzN
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20131017/0364583f/attachment.html>
