[Qgis-developer] someone with experience MetadataUrl
rldhont rldhont at gmail.com
Thu Sep 5 00:09:02 PDT 2013
Hi Alexandre,
Here is the WMS MetadataURL element definition :
A server should use one or more <MetadataURL> elements to offer
detailed, standardized metadata about the
data corresponding to a particular layer. The "type" attribute indicates
the standard to which the metadata
complies. Two "type" attribute values are defined by this International
Standard: the value "ISO 19115:2003"
refers to ISO 19115:2003; the value "FGDC:1998" refers to
FGDC-STD-001-1998 [1]. An information community
may define meanings for other "type" attribute values. The enclosed
<Format> element indicates the file format
MIME type of the metadata record.
MetadataURL has to be link to the Metadata file.
Regards,
René-Luc D'Hont
Le 05/09/2013 00:52, Alexandre Neto a écrit :
> Sorry I got a few typos in the last email.
> Sorry only now I could check the links to use on the metadata example
> for qgis user manual.
> I'm not being able to do it. For the René-Luc examples from bretagne
> I'm not being able to download the data it self (it's password protected)
> For INSPIRE data, I'm not being able to get the metadata link.
> Also, after introdution of both data and metadata url, what is
> supposed to appear in the metadata menu?
> Thanks again for the help.
> On Wed, Sep 4, 2013 at 11:49 PM, Alexandre Neto <senhor.neto at gmail.com
> <mailto:senhor.neto at gmail.com>> wrote:
>     Sorry only now I could check the link to use on the metadata example.
>     bretagne I'm being able to get the data it self (it's password
>     protected)
>     Also, After intordution of both data and metadata url, what is
>     Alexandre Neto
>     On Tue, Aug 27, 2013 at 3:47 PM, Alexandre Neto
>     <senhor.neto at gmail.com <mailto:senhor.neto at gmail.com>> wrote:
>         Thanks,
>         I will try to use one of those.
>         Regards,
>         Alexandre Neto
>         On Tue, Aug 27, 2013 at 11:22 AM, rldhont <rldhont at gmail.com
>         <mailto:rldhont at gmail.com>> wrote:
>             Hi,
>             Here is a Metadata URL :
>             http://geobretagne.fr/geonetwork/srv/fr/iso19139.xml?id=2791
>             And here is a Data URL :
>             http://geobretagne.fr/geonetwork/srv/fr/metadata.show?uuid=abe1149d-5a8d-4dbf-9140-97294b22bd4f
>             The link you provide can be use has a Data URL :
>             http://www.eea.europa.eu/data-and-maps/data/natura-3#tab-metadata
>             Regards,
>             René-Luc D'Hont
>             3Liz
>             Le 27/08/2013 12:13, Alexandre Neto a écrit :
>>             Hello René-Luc,
>>             Can you provide us one of those dataset and respective
>>             dataset?
>>             I have tried to use this dataset:
>>             But I can't find the URL to the metadata.
>>             Thanks,
>>             Alexandre Neto
>>             On Mon, Aug 26, 2013 at 4:58 PM, rldhont
>>             <rldhont at gmail.com <mailto:rldhont at gmail.com>> wrote:
>>                 Hi Larissa,
>>                 MetadatUrl is a web URL link to a metadata file, like
>>                 an URL Link to an INSPIRE metadat file.
>>                 Regards,
>>                 René-Luc
>>                 Le 26/08/2013 15:41, Larissa Junek a écrit :
>>                     Hello lists,
>>                     the user manual team looks for someone who has
>>                     experience with Metadata
>>                     in QGIS. Can you give an example of free geodata
>>                     that have a
>>                     MetadataUrl?
>>                     We would like to insert this example into the
>>                     user manual.
>>                     Kind regards,
>>                     Larissa Junek
>>                     _______________________________________________
>>                     Qgis-developer mailing list
>>                     Qgis-developer at lists.osgeo.org
>>                     <mailto:Qgis-developer at lists.osgeo.org>
>>                     http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130905/fd264cb0/attachment-0001.html>
