[Qgis-developer] grass plugin missing from (nightly) standalone installer
Jürgen E. Fischer jef at norbit.de
Fri Sep 6 03:22:40 PDT 2013
Hi Giovanni,
On Fri, 06. Sep 2013 at 11:20:08 +0100, Giovanni Manghi wrote:
> not sure if is something that should worry, but I noticed that in the
> nigtly windows standalone installer there is no grass plugin and grass
> itself (installed by same installer) is not working ("The procedure
> entry point libintl_setlocale could not be located in the dynamic link
> library libintl-8.dll"). Should I file a ticket?
Which nightly windows standalone installer are you referring  to?
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)                                   IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
