[Qgis-developer] [Qgis-user] Format conversion QGIS 2.0
Alex Mandel tech_dev at wildintellect.com
Mon Sep 16 22:21:56 PDT 2013
As far as I can tell, it affects all formats. You have to manually
change the -of parameter of gdal_translate in the bottom box. At this
point, no it will likely not be fixed in 2.0 as that's already gone to
packaging. GDAL_tools is a python plugin though, so I'm wondering if we
might just be able to push a fix via the python plugin manager and then
users will be able to pick up the update.
Thanks,
Alex
On 09/16/2013 07:31 PM, Partha Sarathi Ghose wrote:
> Hi All,
> It seems a similar problem happens when while converting to idrisi format
> too. While the .rst extension get written, the .rdc does not get created
> and thus in the later stages it becomes difficult to work with idrisi
> format of files. Is there a way to take care of this issue and do you think
> this would be taken care of in the final version?
> Regards
> Partha
> On Mon, Sep 16, 2013 at 11:55 PM, Paolo Cavallini <cavallini at faunalia.it>wrote:
>>  [image: Boxbe] <https://www.boxbe.com/overview> cavallini at faunalia.it is
>> not on your Guest List<https://www.boxbe.com/approved-list?tc_serial=15148098892&tc_rand=1223463893&utm_source=stf&utm_medium=email&utm_campaign=ANNO_MWTP&utm_content=001&token=qFu%2BFusGAh%2Fu7FBmJl%2FKu2%2F0i2z5UmB0TunaHOcrAJZogGzPI%2BmcN3RBpz%2BNtrnR&key=ajCBA4GcTPbxIUZp%2BeHnNuAQlGc%2FMlFOy6uxqOJqv6w%3D>| Approve
>> sender<https://www.boxbe.com/anno?tc_serial=15148098892&tc_rand=1223463893&utm_source=stf&utm_medium=email&utm_campaign=ANNO_MWTP&utm_content=001&token=qFu%2BFusGAh%2Fu7FBmJl%2FKu2%2F0i2z5UmB0TunaHOcrAJZogGzPI%2BmcN3RBpz%2BNtrnR&key=ajCBA4GcTPbxIUZp%2BeHnNuAQlGc%2FMlFOy6uxqOJqv6w%3D>| Approve
>> domain<https://www.boxbe.com/anno?tc_serial=15148098892&tc_rand=1223463893&utm_source=stf&utm_medium=email&utm_campaign=ANNO_MWTP&utm_content=001&dom&token=qFu%2BFusGAh%2Fu7FBmJl%2FKu2%2F0i2z5UmB0TunaHOcrAJZogGzPI%2BmcN3RBpz%2BNtrnR&key=ajCBA4GcTPbxIUZp%2BeHnNuAQlGc%2FMlFOy6uxqOJqv6w%3D>
>> On 2013-09-16 20:17, Alex Mandel wrote:
>>  I can confirm this bug, forwarding to the developer list. Temporary
>>> workaround, is to press the pencil button and edit the -of part of the
>>> command to the correct format as listed on http://gdal.org/formats_list.*
>>> *html <http://gdal.org/formats_list.html>
>>> In this case it should say "-of AAIGrid"
>> Hi all.
>> It looks easy to fix: would it be worth a 2.0.2 release?
>> All the best.
