[Qgis-developer] processing not finding saga
Victor Olaya volayaf at gmail.com
Tue Sep 17 03:21:29 PDT 2013
I think that in Windows only saga 2.1 should be packaged, since there
is no point on using 2.0.8, and have 2.1 compatibility as the default
option
2013/9/17 Paolo Cavallini <cavallini at faunalia.it>:
> On 2013-09-17 12:15, Victor Olaya wrote:
>> The fix for that problem was introduced just after the release branch
>> was made, but I think the package should contain the fix (that's what
>> was mentioned on IRC when I told about adding that last minute
>> change)....but not sure it does. Can you find the git commit it
>> correspond to, so I can check it? For the Processing workshop, the
>> latest version of the plugin could be installed separately, but that
>> might be too much hassle...
> agreed. would it be possible to have new packages then? this might also
> allow to fix the raster conversion issue.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
