[Qgis-developer] Processing report: first issues
Victor Olaya volayaf at gmail.com
Fri Sep 20 12:15:54 PDT 2013
Is that 2.0.1 that you were using in those win machines. The
standalone installer was working perfectly here in 10 computer with
win 7... Hopefully we will be able to prepare a new version of
Processing, to release it independently quite soon. I hope the problem
i there and easy to fix, but it might be in the SAGA installation, so
it might require a new QGIS version :-(
2013/9/20 matteo <matteo.ghetta at gmail.com>:
>>> * all Ubuntu machines could not run saga, because they have 2.0.7
>> you need to add a PPA with saga 2.10.
> mmm.. I work with Ubuntu (13.04), but if I add the repository for the 2.1
> version of saga, there is a conflict between gdal libraries.
> So it seems that it's not possible to install saga and the new qgis version
> at the same time (without compiling)
> Matteo
> Qgis-developer mailing list
