[Qgis-developer] Add yourself to the QGIS Contributor Map
Tim Sutton lists at linfiniti.com
Sat Sep 21 16:44:14 PDT 2013
Hi
On Sat, Sep 21, 2013 at 8:43 PM, Etienne Tourigny
<etourigny.dev at gmail.com>wrote:
> where can we see the actual, updated map? The source is in the master
> tree, but I have not seen in in the QGIS about dialogs.
If you go here
https://github.com/qgis/QGIS/blob/master/doc/contributors.json you will see
it on a map. I used the map in the keynote speech at foss4g2013. In future
versions of QGIS, sure we could include it somewhere in a dialog of you
thought that would be a useful thing to do.
Regards
Tim
> cheers
> On Fri, Sep 20, 2013 at 4:54 AM, Tim Sutton <lists at linfiniti.com> wrote:
>> Hi
>> On Fri, Sep 20, 2013 at 1:55 AM, Etienne Tourigny <
>> etourigny.dev at gmail.com> wrote:
>>> I get a blank document
>> It should be back now
>> Regards
>> Tim
>>> On Thu, Sep 19, 2013 at 6:35 PM, Tim Sutton <lists at linfiniti.com> wrote:
>>>> Hi
>>>> On Thu, Sep 19, 2013 at 3:12 PM, Gino Pirelli <luipir at gmail.com> wrote:
>>>>> I can change to Unknow... that date was related to my repo. I
>>>>> presented code in Brighton but I can't do pull request until some
>>>>> burocratic problems are resolved.
>>>>> But it's ok leaving with unknow (as pcav)... but I prefer to "stay" in
>>>>> this list because my last tree month of work in the communtiy.... it it's
>>>>> not a problem, obviously.
>>>>> thanks, Luigi Pirelli (luigi.pirelli at faunalia.it)
>>>> Just put the date of your first contribution if you know it.
>>>> Regards
>>>> Tim
>>>>> On 19 September 2013 14:38, Borys Jurgiel <lists at borysjurgiel.pl>wrote:
>>>>>> Please everybody check your first commit date. By setting JEF's first
>>>>>> contribution to 2013 we seriously mess the Earth history :) Gino's
>>>>>> date looks
>>>>>> suspicious too. I haven't check others.
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Tim Sutton - QGIS Project Steering Committee Member
>>>> Please do not email me off-list with technical
>>>> support questions. Using the lists will gain
>>>> more exposure for your issues and the knowledge
>>>> surrounding your issue will be shared with all.
>>>> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130922/d5235e10/attachment-0001.html>
