[Qgis-developer] How to use intersects and difference using API c++?
Marco Gomes marco.gomes at edisoft.pt
Mon Sep 23 02:08:27 PDT 2013
I am using the code below to test for geometry intersection and in case
of success remove the intersection part from another geometry, but it is
not working.
The polygonCoverageAreasLayer is a memory polygon layer, and feature is
circle built using rubberBand and the final result is still a circle and
not the difference with my base map costalLineLayer.
                           polygonCoverageAreasLayer->startEditing();
                           attrListCL =
costalLineLayer->dataProvider()->attributeIndexes();
costalLineLayer->dataProvider()->select(attrListCL);
while(costalLineLayer->dataProvider()->nextFeature(featureCL))
                                  if
(feature.geometry()->intersects(featureCL.geometry()))
                                        QgsGeometry *geom =
feature.geometry()->difference(featureCL.geometry());
                                        feature.setGeometry(geom);
//applying new geometry
polygonCoverageAreasLayer->updateFeature(feature);
                           polygonCoverageAreasLayer->commitChanges();
Any clue, for what I am doing wrong?
Thanks
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130923/a92fa975/attachment.html>
