[Qgis-developer] QGIS 2.0 and GRASS integration on OSX and Windows
Pedro Venâncio pedrongvenancio at yahoo.com
Tue Sep 24 11:47:12 PDT 2013
Hi Giovanni,
I've been doing a set of tests on Windows, with the binaries that are today on QGIS website (I think they are new).
As you found, everything works with OSGeo4W version.
With standalone versions, SAGA is already included (although with different versions, which in my view is not good) and it works, but GRASS doesn't. In addition, the drivers included in one and another version are slightly different:
--> QGIS 64 (QGIS-OSGeo4W-2.0.1-2-Setup-x86_64.exe)
License overview:
1. QGIS
2. MrSID Raster Plugin for GDAL
3. OGR FileGDB Driver
4. ECW Raster Plugin for GDAL
5. Oracle Instant Client
--> QGIS 32 (QGIS-OSGeo4W-2.0.1-2-Setup-x86.exe)
License overview:
1. QGIS
3. Oracle Instant Client
I leave the logs of execution of GRASS r.shaded.relief in the 3 versions, may help in diagnosing the problem. As I mentioned, with OSGeo4W GRASS works, and with both standalone versions it fails.
--> OSGeo4W
Algorithm r.shaded.relief - Creates shaded relief from an elevation layer (DEM). started
g.proj -c proj4="+proj=tmerc +lat_0=39.66825833333333 +lon_0=-8.133108333333334 +k=1 +x_0=0 +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
r.external input="D:\SIG\MDT\dem_srtm_pttm06_80m.tif" band=1 output=tmp138004311182 --overwrite -o
g.region n=278040.0 s=-302040.0 e=164040.0 w=-120040.0 res=80.0
r.shaded.relief map=tmp138004311182 altitude=30 azimuth=270 zmult=1 scale=1 units=none shadedmap=shadedmap027dc452787a435e8433600704be9edf --overwrite
g.region rast=shadedmap027dc452787a435e8433600704be9edf
r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=shadedmap027dc452787a435e8433600704be9edf output="C:\Users\sig\AppData\Local\Temp\processing\ab62c133f34d4f46ac86c68048366549\shadedmap.tif"
C:\OSGeo4W\bin>set HOME=C:\Users\sig
C:\OSGeo4W\bin>set GISRC=C:\Users\sig\.qgis2\\processing\processing.gisrc
C:\OSGeo4W\bin>set GRASS_SH=C:/OSGeo4W/apps\msys\bin\sh.exe
C:\OSGeo4W\bin>set PATH=C:/OSGeo4W/apps\msys\bin;C:/OSGeo4W/apps\msys\lib;C:/OSGeo4W/apps/grass/GRASS-~1.3/bin;C:/OSGeo4W/apps/grass/GRASS-~1.3/scripts;C:/OSGeo4W/apps/qgis/./grass/scripts/;C:/OSGeo4W/bin;C:\OSGeo4W\apps\grass\grass-6.4.3\bin;C:\OSGeo4W\apps\msys\bin;C:\OSGeo4W\bin;%GTK_BASEPATH%\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\R\R-2.11.1\bin;C:\Program Files (x86)\ggobi;C:\Program Files (x86)\Java\jre6\bin;C:\Program Files\tcc;D:\mapguide\PostgreSQL_64bits\9.1\bin;C:\Program Files\OSGeo\MapGuide\Web\Php\;C:\Python27;C:\Program Files (x86)\Panda Security\WaAgent\Common;C:\Program Files\SafeNet\Authentication\SAC\x32;C:\Program Files\SafeNet\Authentication\SAC\x64;C:\Program Files
 (x86)\ano\anoSigner;C:\Windows\System32;;C:\OSGeo4W\apps\msys\bin;C:\OSGeo4W\apps\Python27\Scripts;C:\OSGeo4W\apps\qgis\bin;C:\OSGeo4W\apps\grass\grass-6.4.3\lib
C:\OSGeo4W\bin>set WINGISBASE=C:/OSGeo4W/apps\grass\grass-6.4.3
C:\OSGeo4W\bin>set GISBASE=C:/OSGeo4W/apps\grass\grass-6.4.3
C:\OSGeo4W\bin>set GRASS_PROJSHARE=C:/OSGeo4W/apps\grass\grass-6.4.3\share\proj
C:\OSGeo4W\bin>set GRASS_MESSAGE_FORMAT=gui
C:\OSGeo4W\bin>if "" == "" set PATH=C:/OSGeo4W/apps\grass\grass-6.4.3\bin;C:/OSGeo4W/apps\grass\grass-6.4.3\lib;C:/OSGeo4W/apps\msys\bin;C:/OSGeo4W/apps\msys\lib;C:/OSGeo4W/apps/grass/GRASS-~1.3/bin;C:/OSGeo4W/apps/grass/GRASS-~1.3/scripts;C:/OSGeo4W/apps/qgis/./grass/scripts/;C:/OSGeo4W/bin;C:\OSGeo4W\apps\grass\grass-6.4.3\bin;C:\OSGeo4W\apps\msys\bin;C:\OSGeo4W\bin;%GTK_BASEPATH%\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\R\R-2.11.1\bin;C:\Program Files (x86)\ggobi;C:\Program Files (x86)\Java\jre6\bin;C:\Program Files\tcc;D:\mapguide\PostgreSQL_64bits\9.1\bin;C:\Program Files\OSGeo\MapGuide\Web\Php\;C:\Python27;C:\Program Files (x86)\Panda Security\WaAgent\Common;C:\Program Files\SafeNet\Authentication\SAC\x32;C:\Program Files\SafeNet\Authentication\SAC\x64;C:\Program Files
C:\OSGeo4W\bin>if not "" == "" set PATH=C:/OSGeo4W/apps\grass\grass-6.4.3\bin;C:/OSGeo4W/apps\grass\grass-6.4.3\lib;;C:/OSGeo4W/apps\grass\grass-6.4.3\bin;C:/OSGeo4W/apps\grass\grass-6.4.3\lib;C:/OSGeo4W/apps\msys\bin;C:/OSGeo4W/apps\msys\lib;C:/OSGeo4W/apps/grass/GRASS-~1.3/bin;C:/OSGeo4W/apps/grass/GRASS-~1.3/scripts;C:/OSGeo4W/apps/qgis/./grass/scripts/;C:/OSGeo4W/bin;C:\OSGeo4W\apps\grass\grass-6.4.3\bin;C:\OSGeo4W\apps\msys\bin;C:\OSGeo4W\bin;%GTK_BASEPATH%\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\R\R-2.11.1\bin;C:\Program Files (x86)\ggobi;C:\Program Files (x86)\Java\jre6\bin;C:\Program Files\tcc;D:\mapguide\PostgreSQL_64bits\9.1\bin;C:\Program Files\OSGeo\MapGuide\Web\Php\;C:\Python27;C:\Program Files (x86)\Panda Security\WaAgent\Common;C:\Program Files\SafeNet\Authentication\SAC\x32;C:\Program
 Files\SafeNet\Authentication\SAC\x64;C:\Program Files (x86)\ano\anoSigner;C:\Windows\System32;;C:\OSGeo4W\apps\msys\bin;C:\OSGeo4W\apps\Python27\Scripts;C:\OSGeo4W\apps\qgis\bin;C:\OSGeo4W\apps\grass\grass-6.4.3\lib
C:\OSGeo4W\bin>set GRASS_VERSION=6.4.0
C:\OSGeo4W\bin>if not "" == "" goto langset
C:\OSGeo4W\bin>FOR /F "usebackq delims==" %i IN (`"C:/OSGeo4W/apps\grass\grass-6.4.3\etc\winlocale"`) DO @set LANG=%i
C:\OSGeo4W\bin>set PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.PY
C:\OSGeo4W\bin>set PYTHONPATH=C:/OSGeo4W/apps/grass/GRASS-~1.3/etc/python;C:\Program Files (x86)\ArcGIS\bin;C:/OSGeo4W/apps\grass\grass-6.4.3\etc\python;C:/OSGeo4W/apps\grass\grass-6.4.3\etc\wxpython\n
C:\OSGeo4W\bin>g.gisenv.exe set="MAPSET=PERMANENT"
C:\OSGeo4W\bin>g.gisenv.exe set="LOCATION=temp_location"
C:\OSGeo4W\bin>g.gisenv.exe set="LOCATION_NAME=temp_location"
C:\OSGeo4W\bin>g.gisenv.exe set="GISDBASE=C:\Users\sig\AppData\Local\Temp\processing\grassdata"
C:\OSGeo4W\bin>g.gisenv.exe set="GRASS_GUI=text"
C:\OSGeo4W\bin>g.proj -c proj4="+proj=tmerc +lat_0=39.66825833333333 +lon_0=-8.133108333333334 +k=1 +x_0=0 +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
GRASS_INFO_MESSAGE(1408,1): Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default
GRASS_INFO_END(1408,1)
GRASS_INFO_MESSAGE(1408,2): Projection information updated
GRASS_INFO_END(1408,2)
C:\OSGeo4W\bin>r.external input="D:\SIG\MDT\dem_srtm_pttm06_80m.tif" band=1 output=tmp138004311182 --overwrite -o
GRASS_INFO_WARNING(4036,1): Over-riding projection check
GRASS_INFO_END(4036,1)
GRASS_INFO_MESSAGE(4036,2): Importing band 1 of 1...
GRASS_INFO_END(4036,2)
GRASS_INFO_MESSAGE(4036,3): Link to raster map created
GRASS_INFO_END(4036,3)
C:\OSGeo4W\bin>g.region n=278040.0 s=-302040.0 e=164040.0 w=-120040.0 res=80.0
C:\OSGeo4W\bin>r.shaded.relief map=tmp138004311182 altitude=30 azimuth=270 zmult=1 scale=1 units=none shadedmap=shadedmap027dc452787a435e8433600704be9edf --overwrite
GRASS_INFO_MESSAGE(3020,1): Calculating shading, please stand by.
GRASS_INFO_END(3020,1)
GRASS_INFO_MESSAGE(2128,1): Color table for raster map set to 'grey'
GRASS_INFO_END(2128,1)
GRASS_INFO_MESSAGE(4064,1): Shaded relief map created and named .
GRASS_INFO_END(4064,1)
C:\OSGeo4W\bin>g.region rast=shadedmap027dc452787a435e8433600704be9edf
C:\OSGeo4W\bin>r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=shadedmap027dc452787a435e8433600704be9edf output="C:\Users\sig\AppData\Local\Temp\processing\ab62c133f34d4f46ac86c68048366549\shadedmap.tif"
GRASS_INFO_MESSAGE(1356,1): Exporting to GDAL data type: Float64
GRASS_INFO_END(1356,1)
GRASS_INFO_MESSAGE(1356,2): Checking GDAL data type and nodata value
GRASS_INFO_END(1356,2)
GRASS_INFO_MESSAGE(1356,3): Input raster map contains cells with NULL-value (no-data). The value nan will be used to represent no-data values in the input map. You can specify a nodata value with the nodata option.
GRASS_INFO_END(1356,3)
GRASS_INFO_MESSAGE(1356,4): Exporting to GDAL raster
GRASS_INFO_END(1356,4)
GRASS_INFO_MESSAGE(1356,5): r.out.gdal completo.
GRASS_INFO_END(1356,5)
C:\OSGeo4W\bin>exit
Converting outputs
Loading resulting layers
Algorithm r.shaded.relief - Creates shaded relief from an elevation layer (DEM). finished
r.external input="D:\SIG\MDT\dem_srtm_pttm06_80m.tif" band=1 output=tmp1380041233956 --overwrite -o
r.shaded.relief map=tmp1380041233956 altitude=30 azimuth=270 zmult=1 scale=1 units=none shadedmap=shadedmap8a0c0ae932d840e38f63e2e39c026e0c --overwrite
g.region rast=shadedmap8a0c0ae932d840e38f63e2e39c026e0c
r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=shadedmap8a0c0ae932d840e38f63e2e39c026e0c output="C:\Users\sig\AppData\Local\Temp\processing\fa78664f3a934278a245a018cf8884fb\shadedmap.tif"
C:\PROGRA~1\QGISDU~1\bin>set HOME=C:\Users\sig
C:\PROGRA~1\QGISDU~1\bin>set GISRC=C:\Users\sig\.qgis2\\processing\processing.gisrc
C:\PROGRA~1\QGISDU~1\bin>set GRASS_SH=C:/PROGRA~1/QGISDU~1/apps\msys\bin\sh.exe
C:\PROGRA~1\QGISDU~1\bin>set PATH=C:/PROGRA~1/QGISDU~1/apps\msys\bin;C:/PROGRA~1/QGISDU~1/apps\msys\lib;C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/bin;C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/scripts;C:/PROGRA~1/QGISDU~1/apps/qgis/./grass/scripts/;C:/PROGRA~1/QGISDU~1/bin;C:\PROGRA~1\QGISDU~1\apps\grass\grass-6.4.3\bin;C:\PROGRA~1\QGISDU~1\apps\msys\bin;C:\PROGRA~1\QGISDU~1\apps\Python27\Scripts;C:\PROGRA~1\QGISDU~1\bin;%GTK_BASEPATH%\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\R\R-2.11.1\bin;C:\Program Files (x86)\ggobi;C:\Program Files (x86)\Java\jre6\bin;C:\Program Files\tcc;D:\mapguide\PostgreSQL_64bits\9.1\bin;C:\Program Files\OSGeo\MapGuide\Web\Php\;C:\Python27;C:\Program Files (x86)\Panda Security\WaAgent\Common;C:\Program Files\SafeNet\Authentication\SAC\x32;C:\Program
 Files\SafeNet\Authentication\SAC\x64;C:\Program Files (x86)\ano\anoSigner;C:\Windows\System32;;C:\PROGRA~1\QGISDU~1\apps\msys\bin;C:\PROGRA~1\QGISDU~1\apps\qgis\bin;C:\PROGRA~1\QGISDU~1\apps\grass\grass-6.4.3\lib
C:\PROGRA~1\QGISDU~1\bin>set WINGISBASE=C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3
C:\PROGRA~1\QGISDU~1\bin>set GISBASE=C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3
C:\PROGRA~1\QGISDU~1\bin>set GRASS_PROJSHARE=C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\share\proj
C:\PROGRA~1\QGISDU~1\bin>set GRASS_MESSAGE_FORMAT=gui
C:\PROGRA~1\QGISDU~1\bin>if "" == "" set PATH=C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\bin;C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\lib;C:/PROGRA~1/QGISDU~1/apps\msys\bin;C:/PROGRA~1/QGISDU~1/apps\msys\lib;C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/bin;C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/scripts;C:/PROGRA~1/QGISDU~1/apps/qgis/./grass/scripts/;C:/PROGRA~1/QGISDU~1/bin;C:\PROGRA~1\QGISDU~1\apps\grass\grass-6.4.3\bin;C:\PROGRA~1\QGISDU~1\apps\msys\bin;C:\PROGRA~1\QGISDU~1\apps\Python27\Scripts;C:\PROGRA~1\QGISDU~1\bin;%GTK_BASEPATH%\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\R\R-2.11.1\bin;C:\Program Files (x86)\ggobi;C:\Program Files (x86)\Java\jre6\bin;C:\Program Files\tcc;D:\mapguide\PostgreSQL_64bits\9.1\bin;C:\Program Files\OSGeo\MapGuide\Web\Php\;C:\Python27;C:\Program Files (x86)\Panda
 Security\WaAgent\Common;C:\Program Files\SafeNet\Authentication\SAC\x32;C:\Program Files\SafeNet\Authentication\SAC\x64;C:\Program Files (x86)\ano\anoSigner;C:\Windows\System32;;C:\PROGRA~1\QGISDU~1\apps\msys\bin;C:\PROGRA~1\QGISDU~1\apps\qgis\bin;C:\PROGRA~1\QGISDU~1\apps\grass\grass-6.4.3\lib
C:\PROGRA~1\QGISDU~1\bin>if not "" == "" set PATH=C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\bin;C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\lib;;C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\bin;C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\lib;C:/PROGRA~1/QGISDU~1/apps\msys\bin;C:/PROGRA~1/QGISDU~1/apps\msys\lib;C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/bin;C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/scripts;C:/PROGRA~1/QGISDU~1/apps/qgis/./grass/scripts/;C:/PROGRA~1/QGISDU~1/bin;C:\PROGRA~1\QGISDU~1\apps\grass\grass-6.4.3\bin;C:\PROGRA~1\QGISDU~1\apps\msys\bin;C:\PROGRA~1\QGISDU~1\apps\Python27\Scripts;C:\PROGRA~1\QGISDU~1\bin;%GTK_BASEPATH%\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\R\R-2.11.1\bin;C:\Program Files (x86)\ggobi;C:\Program Files (x86)\Java\jre6\bin;C:\Program
 Files\tcc;D:\mapguide\PostgreSQL_64bits\9.1\bin;C:\Program Files\OSGeo\MapGuide\Web\Php\;C:\Python27;C:\Program Files (x86)\Panda Security\WaAgent\Common;C:\Program Files\SafeNet\Authentication\SAC\x32;C:\Program Files\SafeNet\Authentication\SAC\x64;C:\Program Files (x86)\ano\anoSigner;C:\Windows\System32;;C:\PROGRA~1\QGISDU~1\apps\msys\bin;C:\PROGRA~1\QGISDU~1\apps\qgis\bin;C:\PROGRA~1\QGISDU~1\apps\grass\grass-6.4.3\lib
C:\PROGRA~1\QGISDU~1\bin>set GRASS_VERSION=6.4.0
C:\PROGRA~1\QGISDU~1\bin>if not "" == "" goto langset
C:\PROGRA~1\QGISDU~1\bin>FOR /F "usebackq delims==" %i IN (`"C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\etc\winlocale"`) DO @set LANG=%i
C:\PROGRA~1\QGISDU~1\bin>set PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.PY
C:\PROGRA~1\QGISDU~1\bin>set PYTHONPATH=C:/PROGRA~1/QGISDU~1/apps/grass/GRASS-~1.3/etc/python;C:\Program Files (x86)\ArcGIS\bin;C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\etc\python;C:/PROGRA~1/QGISDU~1/apps\grass\grass-6.4.3\etc\wxpython\n
C:\PROGRA~1\QGISDU~1\bin>g.gisenv.exe set="MAPSET=PERMANENT"
C:\PROGRA~1\QGISDU~1\bin>g.gisenv.exe set="LOCATION=temp_location"
C:\PROGRA~1\QGISDU~1\bin>g.gisenv.exe set="LOCATION_NAME=temp_location"
C:\PROGRA~1\QGISDU~1\bin>g.gisenv.exe set="GISDBASE=C:\Users\sig\AppData\Local\Temp\processing\grassdata"
C:\PROGRA~1\QGISDU~1\bin>g.gisenv.exe set="GRASS_GUI=text"
C:\PROGRA~1\QGISDU~1\bin>g.proj -c proj4="+proj=tmerc +lat_0=39.66825833333333 +lon_0=-8.133108333333334 +k=1 +x_0=0 +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
GRASS_INFO_MESSAGE(8336,1): Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default
GRASS_INFO_END(8336,1)
GRASS_INFO_MESSAGE(8336,2): Projection information updated
GRASS_INFO_END(8336,2)
C:\PROGRA~1\QGISDU~1\bin>r.external input="D:\SIG\MDT\dem_srtm_pttm06_80m.tif" band=1 output=tmp1380041233956 --overwrite -o
GRASS_INFO_WARNING(7644,1): Over-riding projection check
GRASS_INFO_END(7644,1)
GRASS_INFO_MESSAGE(7644,2): Importing band 1 of 1...
GRASS_INFO_END(7644,2)
GRASS_INFO_MESSAGE(7644,3): Link to raster map created
GRASS_INFO_END(7644,3)
C:\PROGRA~1\QGISDU~1\bin>g.region n=278040.0 s=-302040.0 e=164040.0 w=-120040.0 res=80.0
C:\PROGRA~1\QGISDU~1\bin>r.shaded.relief map=tmp1380041233956 altitude=30 azimuth=270 zmult=1 scale=1 units=none shadedmap=shadedmap8a0c0ae932d840e38f63e2e39c026e0c --overwrite
GRASS_INFO_MESSAGE(7752,1): Calculating shading, please stand by.
GRASS_INFO_END(7752,1)
GRASS_INFO_ERROR(1316,1): Unable to load GDAL library
GRASS_INFO_END(1316,1)
GRASS_INFO_ERROR(6692,1): In calculation, script aborted.
GRASS_INFO_END(6692,1)
C:\PROGRA~1\QGISDU~1\bin>g.region rast=shadedmap8a0c0ae932d840e38f63e2e39c026e0c
GRASS_INFO_ERROR(6252,1): Raster map not found
GRASS_INFO_END(6252,1)
C:\PROGRA~1\QGISDU~1\bin>r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=shadedmap8a0c0ae932d840e38f63e2e39c026e0c output="C:\Users\sig\AppData\Local\Temp\processing\fa78664f3a934278a245a018cf8884fb\shadedmap.tif"
GRASS_INFO_ERROR(1656,1): Raster map or group not found
GRASS_INFO_END(1656,1)
C:\PROGRA~1\QGISDU~1\bin>exit
Converting outputs
r.external input="D:\SIG\MDT\dem_srtm_pttm06_80m.tif" band=1 output=tmp1380042310334 --overwrite -o
r.shaded.relief map=tmp1380042310334 altitude=30 azimuth=270 zmult=1 scale=1 units=none shadedmap=shadedmap31403ede145747868a6125e333475699 --overwrite
g.region rast=shadedmap31403ede145747868a6125e333475699
r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=shadedmap31403ede145747868a6125e333475699 output="C:\Users\sig\AppData\Local\Temp\processing\6d0d9d36826b4493b1384bcd0e9405a0\shadedmap.tif"
C:\PROGRA~2\QGISDU~1\bin>set HOME=C:\Users\sig
C:\PROGRA~2\QGISDU~1\bin>set GISRC=C:\Users\sig\.qgis2\\processing\processing.gisrc
C:\PROGRA~2\QGISDU~1\bin>set GRASS_SH=C:/PROGRA~2/QGISDU~1/apps\msys\bin\sh.exe
C:\PROGRA~2\QGISDU~1\bin>set PATH=C:/PROGRA~2/QGISDU~1/apps\msys\bin;C:/PROGRA~2/QGISDU~1/apps\msys\lib;C:\PROGRA~2\QGISDU~1\apps\grass\grass-6.4.3\bin;C:\PROGRA~2\QGISDU~1\apps\msys\bin;C:\PROGRA~2\QGISDU~1\bin;%GTK_BASEPATH%\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\R\R-2.11.1\bin;C:\Program Files (x86)\ggobi;C:\Program Files (x86)\Java\jre6\bin;C:\Program Files\tcc;D:\mapguide\PostgreSQL_64bits\9.1\bin;C:\Program Files\OSGeo\MapGuide\Web\Php\;C:\Python27;C:\Program Files (x86)\Panda Security\WaAgent\Common;C:\Program Files\SafeNet\Authentication\SAC\x32;C:\Program Files\SafeNet\Authentication\SAC\x64;C:\Program Files
 (x86)\ano\anoSigner;C:\Windows\System32;;C:\PROGRA~2\QGISDU~1\apps\msys\bin;C:\PROGRA~2\QGISDU~1\apps\Python27\Scripts;C:\PROGRA~2\QGISDU~1\apps\qgis\bin;C:\PROGRA~2\QGISDU~1\apps\grass\grass-6.4.3\lib
C:\PROGRA~2\QGISDU~1\bin>set WINGISBASE=C:/PROGRA~2/QGISDU~1/apps\grass\grass-6.4.3
C:\PROGRA~2\QGISDU~1\bin>set GISBASE=C:/PROGRA~2/QGISDU~1/apps\grass\grass-6.4.3
C:\PROGRA~2\QGISDU~1\bin>set GRASS_PROJSHARE=C:/PROGRA~2/QGISDU~1/apps\grass\grass-6.4.3\share\proj
C:\PROGRA~2\QGISDU~1\bin>set GRASS_MESSAGE_FORMAT=gui
C:\PROGRA~2\QGISDU~1\bin>if "" == "" set PATH=C:/PROGRA~2/QGISDU~1/apps\grass\grass-6.4.3\bin;C:/PROGRA~2/QGISDU~1/apps\grass\grass-6.4.3\lib;C:/PROGRA~2/QGISDU~1/apps\msys\bin;C:/PROGRA~2/QGISDU~1/apps\msys\lib;C:\PROGRA~2\QGISDU~1\apps\grass\grass-6.4.3\bin;C:\PROGRA~2\QGISDU~1\apps\msys\bin;C:\PROGRA~2\QGISDU~1\bin;%GTK_BASEPATH%\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\R\R-2.11.1\bin;C:\Program Files (x86)\ggobi;C:\Program Files (x86)\Java\jre6\bin;C:\Program Files\tcc;D:\mapguide\PostgreSQL_64bits\9.1\bin;C:\Program Files\OSGeo\MapGuide\Web\Php\;C:\Python27;C:\Program Files (x86)\Panda Security\WaAgent\Common;C:\Program Files\SafeNet\Authentication\SAC\x32;C:\Program Files\SafeNet\Authentication\SAC\x64;C:\Program Files
C:\PROGRA~2\QGISDU~1\bin>if not "" == "" set PATH=C:/PROGRA~2/QGISDU~1/apps\grass\grass-6.4.3\bin;C:/PROGRA~2/QGISDU~1/apps\grass\grass-6.4.3\lib;;C:/PROGRA~2/QGISDU~1/apps\grass\grass-6.4.3\bin;C:/PROGRA~2/QGISDU~1/apps\grass\grass-6.4.3\lib;C:/PROGRA~2/QGISDU~1/apps\msys\bin;C:/PROGRA~2/QGISDU~1/apps\msys\lib;C:\PROGRA~2\QGISDU~1\apps\grass\grass-6.4.3\bin;C:\PROGRA~2\QGISDU~1\apps\msys\bin;C:\PROGRA~2\QGISDU~1\bin;%GTK_BASEPATH%\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\R\R-2.11.1\bin;C:\Program Files (x86)\ggobi;C:\Program Files (x86)\Java\jre6\bin;C:\Program Files\tcc;D:\mapguide\PostgreSQL_64bits\9.1\bin;C:\Program Files\OSGeo\MapGuide\Web\Php\;C:\Python27;C:\Program Files (x86)\Panda Security\WaAgent\Common;C:\Program Files\SafeNet\Authentication\SAC\x32;C:\Program
 Files\SafeNet\Authentication\SAC\x64;C:\Program Files (x86)\ano\anoSigner;C:\Windows\System32;;C:\PROGRA~2\QGISDU~1\apps\msys\bin;C:\PROGRA~2\QGISDU~1\apps\Python27\Scripts;C:\PROGRA~2\QGISDU~1\apps\qgis\bin;C:\PROGRA~2\QGISDU~1\apps\grass\grass-6.4.3\lib
C:\PROGRA~2\QGISDU~1\bin>set GRASS_VERSION=6.4.0
C:\PROGRA~2\QGISDU~1\bin>if not "" == "" goto langset
C:\PROGRA~2\QGISDU~1\bin>FOR /F "usebackq delims==" %i IN (`"C:/PROGRA~2/QGISDU~1/apps\grass\grass-6.4.3\etc\winlocale"`) DO @set LANG=%i
C:\PROGRA~2\QGISDU~1\bin>set PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.PY
C:\PROGRA~2\QGISDU~1\bin>set PYTHONPATH=C:\Program Files (x86)\ArcGIS\bin;C:/PROGRA~2/QGISDU~1/apps\grass\grass-6.4.3\etc\python;C:/PROGRA~2/QGISDU~1/apps\grass\grass-6.4.3\etc\wxpython\n
C:\PROGRA~2\QGISDU~1\bin>g.gisenv.exe set="MAPSET=PERMANENT"
C:\PROGRA~2\QGISDU~1\bin>g.gisenv.exe set="LOCATION=temp_location"
C:\PROGRA~2\QGISDU~1\bin>g.gisenv.exe set="LOCATION_NAME=temp_location"
C:\PROGRA~2\QGISDU~1\bin>g.gisenv.exe set="GISDBASE=C:\Users\sig\AppData\Local\Temp\processing\grassdata"
C:\PROGRA~2\QGISDU~1\bin>g.gisenv.exe set="GRASS_GUI=text"
C:\PROGRA~2\QGISDU~1\bin>g.proj -c proj4="+proj=tmerc +lat_0=39.66825833333333 +lon_0=-8.133108333333334 +k=1 +x_0=0 +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
C:\PROGRA~2\QGISDU~1\bin>r.external input="D:\SIG\MDT\dem_srtm_pttm06_80m.tif" band=1 output=tmp1380042310334 --overwrite -o
C:\PROGRA~2\QGISDU~1\bin>g.region n=278040.0 s=-302040.0 e=164040.0 w=-120040.0 res=80.0
C:\PROGRA~2\QGISDU~1\bin>r.shaded.relief map=tmp1380042310334 altitude=30 azimuth=270 zmult=1 scale=1 units=none shadedmap=shadedmap31403ede145747868a6125e333475699 --overwrite
C:\PROGRA~2\QGISDU~1\bin>g.region rast=shadedmap31403ede145747868a6125e333475699
C:\PROGRA~2\QGISDU~1\bin>r.out.gdal -c createopt="TFW=YES,COMPRESS=LZW" input=shadedmap31403ede145747868a6125e333475699 output="C:\Users\sig\AppData\Local\Temp\processing\6d0d9d36826b4493b1384bcd0e9405a0\shadedmap.tif"
C:\PROGRA~2\QGISDU~1\bin>exit
Converting outputs
Best regards,
Pedro
----- Original Message -----
> Most of our Windows users seem to get a very similar behavior.
Hi Andreas,
as pointed in the past days in another thread it seems that in the
qgis 2.0 standalone installers for Windows GRASS/processing is not
working. SAGA/processing it is also not working but in this case SAGA
does not seems included at all.
They both work if QGIS is installed with osgeo4w.
cheers
-- Giovanni --
