[Qgis-developer] OS X 2.0 packages update
Noli Sicad nsicad at gmail.com
Wed Sep 25 06:45:08 PDT 2013
Hi William,
The OTB plugin is still not working in this update.
I will send you a screenshot of the error.
Noli
On 9/25/13, William Kyngesburye <woklist at kyngchaos.com> wrote:
> Very odd, the package has this library link correct.  Try deleting QGIS.app
> and reinstalling.
> On Sep 25, 2013, at 3:24 AM, Andreas Neumann wrote:
>> Hi William,
>> Thank you for your continuous support on this issue.
>> Unfortunately, GRASS still does not work in my processing environment. It
>> still complains about missing dependencies.
>> In parallel to Processing I am also testing the GRASS plugin.
>> I can successfully create new MAPSETs and open them. The modules are
>> found, but when loading one, e.g. v.surf.rst, I get this error message:
>> Kann Modul v.surf.rst nicht starten
>> DYLD_LIBRARY_PATH=
>> QGIS_PREFIX_PATH=
>> Befehl: /Applications/QGIS.app/Contents/MacOS/grass/bin/v.surf.rst
>> --interface-description
>> dyld: Library not loaded: /usr/local/lib/libfftw3.3.dylib Referenced from:
>> /Applications/QGIS.app/Contents/MacOS/grass/lib/libgrass_gmath.6.4.3.dylib
>> Reason: image not found
>> so it seems to complain about "libfftw3.3.dylib"
>> Andreas
>> On Tue, 24 Sep 2013 20:24:55 -0500, William Kyngesburye wrote:
>>> I did a link hunt and fixed up all the link errors I could find, and
>>> took care of some other packaging problems.
>>> Also, Snow Leopard package is now ready.
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> "History is an illusion caused by the passage of time, and time is an
>>> illusion caused by the passage of history."
>>> - Hitchhiker's Guide to the Galaxy
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
