[Qgis-developer] install instructions
Etienne Tourigny etourigny.dev at gmail.com
Fri Sep 27 14:04:38 PDT 2013
On Fri, Sep 27, 2013 at 4:25 PM, stevenhorner <steven at stevenhorner.com>wrote:
> Etienne Tourigny-3 wrote
> > On Fri, Sep 27, 2013 at 4:11 PM, stevenhorner <
> > steven@
> > >wrote:
> >> I had similar problems installing on raring, like you I had both listed,
> >> but
> >> now use these instructions disable any other source you may have added:
> >> sudo apt-get install python-software-properties
> >> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
> >> sudo apt-get update
> >> sudo apt-get install qgis python-qgis qgis-plugin-grass
> >> This installs but you may get an error when starting QGIS on Ubuntu
> which
> >> is
> >> normally because the owner of the .QGIS2 folder is Root rather than your
> >> logon user. You may need to change this.
> > I experienced the same problem (.qgis2 folder created by root).  Is that
> > folder created by qgis installation? Probably, but very odd.
> > This is a BIG bug and should be fixed, is there a bug report on this?
> > Etienne
> Yes it's on the issue list here:  http://hub.qgis.org/issues/8613
> <http://hub.qgis.org/issues/8613>
sorry just saw that a few minutes ago!
> http://osgeo-org.1560.x6.nabble.com/install-instructions-tp5080617p5080633.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130927/56e2b6e9/attachment.html>
