[Qgis-developer] OS X 2.0 packages update
Noli Sicad nsicad at gmail.com
Fri Sep 27 18:49:23 PDT 2013
Hi William,
In the last screenshot on the OTB Plugin for QGIS 2.0.1-2 Mac OS X
error that I sent you, it seems that there is dynamic library that is
not loading.
"dylb: Library not loaded" (in the screenshot error)
 In compiling OTB Plugin for QGIS 2.0.1-2 Mac OS X, does OTB-Plugin
requires OTB binary installed in your system?
What might be this dynamic library not loading, (i.e. what is this library)?
I hope we can make OTB plugin working in Mac OS X.
Thanks,
Regards, Noli
On 9/25/13, Noli Sicad <nsicad at gmail.com> wrote:
> I deleted QGIS.app before installing.
> I deleted QGIS.app again and reinstalled. Yet I got the same problem,
> OTB is not working as showed in the screenshot that I sent you.
> Noli
> On 9/25/13, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> Again, very odd, it's correct in the installer package.  Try deleting
>> QGIS.app and reinstalling.
>> On Sep 25, 2013, at 8:45 AM, Noli Sicad wrote:
>>> Hi William,
>>> The OTB plugin is still not working in this update.
>>> I will send you a screenshot of the error.
>>> Noli
>>>> Very odd, the package has this library link correct.  Try deleting
>>>> QGIS.app
>>>> and reinstalling.
>>>> On Sep 25, 2013, at 3:24 AM, Andreas Neumann wrote:
>>>>> Hi William,
>>>>> Thank you for your continuous support on this issue.
>>>>> Unfortunately, GRASS still does not work in my processing environment.
>>>>> It
>>>>> still complains about missing dependencies.
>>>>> In parallel to Processing I am also testing the GRASS plugin.
>>>>> I can successfully create new MAPSETs and open them. The modules are
>>>>> found, but when loading one, e.g. v.surf.rst, I get this error
>>>>> message:
>>>>> Kann Modul v.surf.rst nicht starten
>>>>> DYLD_LIBRARY_PATH=
>>>>> QGIS_PREFIX_PATH=
>>>>> Befehl: /Applications/QGIS.app/Contents/MacOS/grass/bin/v.surf.rst
>>>>> --interface-description
>>>>> dyld: Library not loaded: /usr/local/lib/libfftw3.3.dylib Referenced
>>>>> from:
>>>>> /Applications/QGIS.app/Contents/MacOS/grass/lib/libgrass_gmath.6.4.3.dylib
>>>>> Reason: image not found
>>>>> so it seems to complain about "libfftw3.3.dylib"
>>>>> Andreas
>>>>> On Tue, 24 Sep 2013 20:24:55 -0500, William Kyngesburye wrote:
>>>>>> I did a link hunt and fixed up all the link errors I could find, and
>>>>>> took care of some other packaging problems.
>>>>>> Also, Snow Leopard package is now ready.
>>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>>> http://www.kyngchaos.com/
>>>>>> "History is an illusion caused by the passage of time, and time is an
>>>>>> illusion caused by the passage of history."
>>>>>> - Hitchhiker's Guide to the Galaxy
>>>>>> _______________________________________________
>>>>>> Qgis-developer mailing list
>>>>>> Qgis-developer at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> First Pogril: Why is life like sticking your head in a bucket filled with
>> hyena offal?
>> Second Pogril: I don't know.  Why IS life like sticking your head in a
>> bucket filled with hyena offal?
>> First Pogril: I don't know either.  Wretched, isn't it?
>> -HitchHiker's Guide to the Galaxy
