[Qgis-developer] Issues with GRASS plugin
Paolo Cavallini cavallini at faunalia.it
Wed Apr 2 09:55:02 PDT 2014
Sorry, sending it too fast.
Hi.
Thanks for checking. Notes inline. Pretty bad stuff. Anybody plans to
fix this?
Il 01/04/2014 21:20, Giovanni Manghi ha scritto:
>> I open a raster, click on Edit grass region, change just the resolution,
>> then I run r.slope - > the resulting map has the resolution of the input
>> dtm, not that defined in the previous step.
> weird, now I can confirm too.
http://hub.qgis.org/issues/9979
>> If I add a vector from GRASS plugin>Toolbox>Browser, with double click
>> or right click -> add to map, I get individual topolayers (1_polygon,
>> topo_point, topo_line, topo_node).
> here crashes qgis
>> From QGIS browser, I get a double entry for grass locations (one as a
>> folder, one as grass layers). The first does not show data, the second
>> does not allow the loading of the whole layer, but only of individual
>> topolayers.
>> It used to behave properly.
http://hub.qgis.org/issues/9980
This makes the plugin pretty useless for vectors, I guess.
>> Moreover, creating a location from qgis extent fails.
>> GRASS 6.4.3-3 and QGIS 2.2 on Debian sid, and standalone on Windows.
> weird again, this seems to work here.
This may well be related to projections (I use 3003 in my trial).
Thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
