[Qgis-developer] Deactivating multi-threaded rendering - Was: QGIS' TimeManager plugin in action
Anita Graser anitagraser at gmx.at
Sat Apr 5 15:05:55 PDT 2014
Hi Nathan,
Am 05.04.2014, 22:54 Uhr, schrieb Nathan Woodrow <madmanwoo at gmail.com>:
> What iisues do you have with your time manager and MTR?
The export image series does not work properly anymore: it sometimes saves
before the map is done rendering.
Maybe there's some signal I could use?
Best wishes,
Anita
> Nathan
> On 06/04/2014 1:11 am, "Anita Graser" <anitagraser at gmx.at> wrote:
>> Hi,
>> Are there plans to let plugins (which are not working well with
>> multi-threaded rendering) deactivate the feature when needed?
>> Thanks and best wishes,
>> Anita
>> Am 04.04.2014, 05:44 Uhr, schrieb Mathieu Pellerin
>> <nirvn.asia at gmail.com>:
>>> Hmm, is there no way to deactivate MTR? As far as I understand, while
>>> we
>>> can de-activate multi-core rendering, the general multi-threaded
>>> rendering
>>> can't be turned off.
>>> On Thu, Apr 3, 2014 at 7:32 PM, Anita Graser
>>> <anita.graser.at at gmail.com>
>>> wrote:
>>>  Hi Mathieu,
>>>> I'm aware of some issues caused by multi-threaded rendering. If
>>>> deactivated, TimeManager should work as always. I currently don't have
>>>> time to look into adjusting it to the multi-threaded rendering.
>>>> Best wishes,
>>>> Anita
>>>> On Thu, Apr 3, 2014 at 2:02 AM, Mathieu Pellerin
>>>> wrote:
>>>> > Any progress upgrading timemanager to be qgis 2.3 compatible?
>>>> > On 2 Apr 2014 23:34, "Anita Graser" <anita.graser.at at gmail.com>
>>>> wrote:
>>>> >> Hi Mathieu,
>>>> >> Thanks for sharing! That's a really well done video on a difficult
>>>> topic.
>>>> >> I've added it to the Time Manager Youtube playlist as well.
>>>> >> Best wishes,
>>>> >> Anita
>>>> >> Am 01.04.2014, 08:41 Uhr, schrieb Mathieu Pellerin <
>>>> >>> Greetings Anita,
>>>> >>> I've just finished a spacial project that relied on your
>>>> TimeManager
>>>> >>> plugin
>>>> >>> to produce a time-lapse of recorded land conflicts in Cambodia
>>>> over
>>>> 13
>>>> >>> years: http://licadho-cambodia.org/video.php?perm=46
>>>> >>> Sharing as I think you might appreciate seeing the great fruits
>>>> your
>>>> tool
>>>> >>> can produce.
>>>> >>> Cheers,
>>>> >>> Math
>>>> >> anitagraser.com
>> anitagraser.com
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
anitagraser.com
