[Qgis-developer] Adding plugins to core?
Etienne Tourigny etourigny.dev at gmail.com
Mon Apr 7 07:42:01 PDT 2014
Since the OpenLayers plugin does not (currently) work with master, perhaps
we can replace it with TMS-based layers, wither through a plugin or as a
native (GDAL-based) provider?
Is there anything in OpenLayers that could not work with GDAL TMS
mini-driver [1] ?
On Mon, Apr 7, 2014 at 7:22 AM, Vincent Picavet <vincent.ml at oslandia.com>wrote:
> Hello,
> Le lundi 7 avril 2014 12:05:05, Nyall Dawson a écrit :
> > On 7 April 2014 18:15, Vincent Picavet <vincent.ml at oslandia.com> wrote:
> > > A good solution though would be to remove google layers and only use
> OSM
> > > and mapbox layers, which begin to be on par in terms of quality.
> > I'm pretty sure this is against MapBox's terms of service too, unless
> > users were made to sign up for a MapBox account and had to add their
> > individual API key to QGIS to unlock MapBox layers:
> > "You must have a Mapbox account to use Mapbox. You are required to
> > register for an account before using the Service. Each request to the
> > API must include your account's unique API identifier. Unauthorized
> > use of any API identifier is prohibited." [1]
> Right, I had not read this through. It would probably be much easier to
> get a
> specific authorization from MapBox than from Google though, given their
> open-
> source orientation.
> > > Or let the user a
> > > deliberate way to add google layers (indicating a URL or something like
> > > this), warning him about the licence.
> > Hmm... while this may be a workable solution to the licensing issue,
> > wouldn't it be a step back in functionality anyway? We'd be trading
> > having a good, working off-the-shelf third-party plugin for a crippled
> > core version which takes user intervention to unlock the same
> > features.
> In any case, there are quite a lot of OSM based layers which can be used
> (HOT,
> OSM.fr, OpenCycleMap...). We can still enhance the plugin with those.
> It would lack an aerial imagery layer though.
> > I'm totally for adding essential plugins to core (or merging the
> > functionality with reimplemented c++ versions), but I honestly don't
> > know if it's workable to do this for the OpenLayers plugin.
> Right, if we remove everything from the plugin except the TMS YXZ layers,
> we
> could also just have a better ergonomy for opening this kind of layers
> through
> GDAL, and have a predefined list of layers accessible on internet (even
> auto-
> updatable by downloading the list).
> Vincent
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140407/908d566c/attachment-0001.html>
