[Qgis-developer] Aliases of features attributes in Mapserver's WMS GetProjectSettings and GetFeatureInfo
Bernhard Ströbl bernhard.stroebl at jena.de
Mon Apr 7 23:17:23 PDT 2014
Hi Marcel,
have you seen this [1]?
Clearly mapserver should stick to either name or alias in _all_
responses. As (I assume) name is unique (because it must be unique in
the data source) and alias may not (because it is a user setting),
mapserver should use the name and (as proposed by you) additionally
provide the alias at least in GetProjectSettings. No idea if
GetCapabilities and GetFeatureInfo should return the alias, too, because
they are standardized requests.
Bernhard
[1] http://hub.qgis.org/issues/8727
Am 08.04.2014 08:05, schrieb Marcel Dancak:
> Hi, I found some issues in Mapserver when using aliases for features
> attributes.
> GetProjectSetting response has features attributes of vector layer in
> this form
> <Attribute typeName="INTEGER" precision="0" length="0"
> editType="LineEdit" type="qlonglong" comment="" name="PK_UID"/>
> where "name" property contains either attribute's alias (if defined) or
> its name. So you are loosing attribute's name when using aliases, and
> that make it impossible to perform searching by this attribute with
> GetFeatureInfo request (with FILTER parameter). Separate "alias"
> property would be much better.
> Another question is, what should be used as attribute name in
> GetFeatureInfo response, alias or name? Current mapserver returns prefer
> aliases (if defined) in plain XML format, but in GML format it always
> returns names. In my opinion, names should be used in both formats and
> aliases could be passed as additional info (if particular format allows
> that), or not used at all in GetFeatureInfo cause clients would be able
> to perform mapping from names to aliases by info from GetProjectSettings.
> And the last issue is that mapserver always returns all features
> attributes in GetFeatureInfo response is GML format, even if they are
> marked to be excluded in WMS server.
> I have all these issues fixed and I can create a pull requests, but
> first I want to discuss about it and maybe another solutions will came out.
> Marcel
__________ Information from ESET Security, version of virus signature database 9648 (20140407) __________
The message was checked by ESET Security.
    part000.txt - is OK
http://www.eset.com
