[Qgis-developer] Identify tool and layer choice
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Tue Apr 8 03:20:15 PDT 2014
Ah and are the geometry type icons still missing on master (just in front of the layer name)?
Stefan
Von meinem iPhone gesendet
> Am 08.04.2014 um 12:02 schrieb "Andreas Neumann" <a.neumann at carto.net>:
> Hi,
> The new layer-choice mode with the drop-down menu is great. It should be
> the default mode of the identify tool in the future, in my opinion.
> However, I saw that if there is a single result you still get the layer
> choice menu with just a single choice. This could be improved to open
> the form directly without having to make a choice first. We have a an
> option in the "Map Tools" settings called "Open feature form, if a
> single feature is identified" - in my opinion this setting should be
> honored if checked.
> Who did this layer choice implementation? Could this be improved?
> Andreas
> Qgis-developer mailing list
