[Qgis-developer] Compiling QGIS on Mavericks
nzfarmer andrew at southweb.co.nz
Fri Apr 11 10:39:41 PDT 2014
Well, after about a week of running battles and some great support from
Larry, I now have a successful dev environment.
I ended up with brew installation as per Larry's instructions:
brew tap osgeo/osgeo4mac
brew install qgis-22 --with-grass --with-globe
The first of these caused warnings and required me to install a few of the
dependencies explicitly - namely gdal, pdal and grass.
i.e brew install osgeo/osgeo4mac/gdal
The globe dependency failed to build but I may revisit this now I have a
working environment.
When I went to replicate the brew so I can work offline, I:
- took a patched version QGIS-Final-2_0_1
- wrote my own build script based on the brew generated parameters
- added the following env vars
export CXX=`which clang++`;
export CXXFLAGS="-F/usr/local/opt/qt/lib"
I can now compile and run the program, and of course start writing some c++
plugins (which was the original goal)
thanks again.
Andrew
View this message in context: http://osgeo-org.1560.x6.nabble.com/Compiling-QGIS-on-Mavericks-tp5134650.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
