[Qgis-developer] [Qgis-user] Installing QGIS Server on RedHat EL 6.5
Matthias Kuhn matthias.kuhn at gmx.ch
Tue Apr 22 22:39:41 PDT 2014
I plan to create new packages for RHEL 7, where the dependencies should
be up to date for current QGIS versions.
I could create packages for older RHEL versions, but that would require
somebody to fund the time necessary to adjust the QGIS code for the
older dependencies.
Best
Matthias
On Die 22 Apr 2014 14:53:24 CEST, Olivier Dalang wrote:
> Hi !
> Still about this : do you plan to continue maintaining packages for
> qgis-mapserver for RHEL ?
> If so, do you have an ETA for 2.2 (or 2.4) ?
> If not, I guess I'll either have to switch distro or learn how to
> compile the mapserver...
> Thanks !
> Olivier
> 2014-03-22 0:00 GMT+01:00 Matthias Kuhn <matthias.kuhn at gmx.ch
> <mailto:matthias.kuhn at gmx.ch>>:
>     2.2 is not that easy because it requires qt>=4.7 and rhel comes with
>     qt-4.6.2.
>     So without reverting some commits or compiling new qt packages (which
>     likely have additional dependencies) this won't be an option.
>     Instead there are now new packages (qgis-2.0.1-2) available which are
>     based on the latest release-2_0 patches (f802808)
>     I tested here in a docker container and was able to install (didn't do
>     any more tests actually):
>     docker pull centos
>     docker run -i -t centos /bin/bash
>     rpm -Uvh
>     http://mirror.karneval.cz/pub/linux/fedora/epel/6/x86_64/epel-release-6-8.noarch.rpm
>     rpm -Uvh http://elgis.argeo.org/repos/6/elgis-release-6-6_0.noarch.rpm
>     wget fedora.vitu.ch/EL/qgis.repo
>     <http://fedora.vitu.ch/EL/qgis.repo> -P /etc/yum.repos.d/
>     rpm --import http://fedora.vitu.ch/Fedora/RPM-GPG-Key-vitu
>     yum update
>     yum install qgis
>     Hope this helps
>     Matthias
>     On Fre 21 Mär 2014 18:19:38 CET, Olivier Dalang wrote:
>     > Great !! Many thanks :)
>     > Do you have an estimate of when you could be done ? (hours / days /
>     > weeks ?)
