[Qgis-developer] compiling qgis with MS visual 2008
otmane yazidi alaoui yazidiotmane at gmail.com
Mon Aug 11 13:35:01 PDT 2014
I really am disappointed because I can not manage to compile the source code
qgis on any platform Mac / Windows 7 nor with MinGW or Visual Studio
still there are problems somewhere even though I followed the instructions
on figurative
QGIS
Building QGIS from source - step by step
Friday July 25, 2014
https://github.com/qgis/QGIS/blob/master/INSTALL#L547
here is the latest error that I had them lately with MS Visual Studio 2009
complilateur
please I need help with this complier source code on any platform mac /
windows / Mingw / VS !!!!!
thank you a lot
Check for working C compiler using: Visual Studio 9 2008
Check for working C compiler using: Visual Studio 9 2008 -- broken
CMake Error at C:/Program Files/CMake
2.8/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:52 (MESSAGE):
The C compiler "cl" is not able to compile a simple test program.
It fails with the following output:
Change Dir: C:/dev/cpp/VS_2008_GGIS/CMakeFiles/CMakeTmp
 Run Build Command:C:\PROGRA~1\MICROS~1.0\Common7\IDE\VCExpress.exe
CMAKE_TRY_COMPILE.sln /build Debug /project cmTryCompileExec
 Microsoft (R) Visual C++ Express Edition Version 9.0.21022.8.
Copyright (C) Microsoft Corp 2007. All rights reserved.
1>------ Build started: Project: cmTryCompileExec, Configuration: Debug
Win32 ------
1>Compiling...
1>Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.21022.08 for
80x86
1>Copyright (C) Microsoft Corporation. All rights reserved.
1>cl /Od /D "WIN32" /D "_WINDOWS" /D "_DEBUG" /D "CMAKE_INTDIR=\"Debug\""
/D "_MBCS" /FD /RTCs /MDd /Fo"cmTryCompileExec.dir\Debug\\"
/Fd"C:\dev\cpp\VS_2008_GGIS\CMakeFiles\CMakeTmp\Debug/cmTryCompileExec.pdb"
/W3 /c /Zi /TC /Zm1000
1> .\testCCompiler.c
1>testCCompiler.c
1>Compiling manifest to resources...
1>Microsoft (R) Windows (R) Resource Compiler Version 6.0.5724.0
1>Linking...
1>Embedding manifest...
1>Project : error PRJ0003 : Error spawning 'cmd.exe'.
1>Build log was saved at
"file://c:\dev\cpp\VS_2008_GGIS\CMakeFiles\CMakeTmp\cmTryCompileExec.dir\Debug\BuildLog.htm"
1>cmTryCompileExec - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped
  CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
CMakeLists.txt:7 (PROJECT)
       YAZIDI ALAOUI OTMANE
           Ingénieur d'état en Géomatique
                   Tel:+212652538743
                   @ :yazidiotmane at gmail.com
http://www.doyoubuzz.com/otmane-yazidi-alaoui
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140811/63e93fa3/attachment.html>
