[Qgis-developer] Struggling with iface.openFeatureForm()
Alexandre Neto senhor.neto at gmail.com
Thu Aug 21 05:05:21 PDT 2014
On Thu, Aug 21, 2014 at 12:45 PM, Bernhard Ströbl <bernhard.stroebl at jena.de>
wrote:
> I tried in master (1.5) after Jürgen's fix and it worked for me (PostGIS I
> think)
> Bernhard
In QGIS 2.5 the problem is different. Opening and editing a new feature
form with openFeatureform(temp_feature) automatically adds it to the layer,
and does not update the temp_feature attributes after you press ok.
I believe that the original behavior were to update the temp_feature
attributes and then you would need to manually add the feature to the layer
with layer.addFeature(temp_feature), this would allow some feature
manipulation between the processes.
Alexandre
> Am 21.08.2014 13:41, schrieb Alexandre Neto:
>> Hi Bernhard,
>> Thanks for the link, I guess that the 2.4 problem was already identified
>> and corrected in master.
>> A bit of update on this matter. Regarding 2.2. I was doing my tests with
>> a dbf layer. With a postgis table is working well. So I can work with
>> that for now.
>> Still, it seems that there is something to fix in 2.5. should I open a
>> ticket?
>> Alexandre Neto
>> On Thu, Aug 21, 2014 at 12:37 PM, Bernhard Ströbl
>> <bernhard.stroebl at jena.de <mailto:bernhard.stroebl at jena.de>> wrote:
>>     Hi Alexandre,
>>     see: http://hub.qgis.org/issues/__10865
>>     <http://hub.qgis.org/issues/10865>
>>     regards
>>     Bernhard
>>     Am 21.08.2014 13 <tel:21.08.2014%2013>:23, schrieb Alexandre Neto:
>>         Hello all,
>>         I'm trying to finish a plugin that was initially designed for 1.8.
>>         Our workflow is currently on QGIS 2.2, but we will update in the
>>         future,
>>         so I'm doing some test in 2.4 and in master.
>>         My goal is to open the feature form of a temporary feature in a
>>         layer,
>>         and keep it's attribute values for future actions.
>>         The code is something like this:
>>              mc = iface.mapCanvas()
>>              layer = mc.currentLayer()
>>              temp_feature = QgsFeature()
>>              attributes = []
>>              # getting default values (for primary keys)
>>              provider = layer.dataProvider()
>>              for j in layer.__pendingAllAttributesList():
>>                   if provider.defaultValue(j):
>>                       attributes.append(provider.__defaultValue(j))
>>                   else:
>>                       attributes.append(None)
>>              temp_feature.setAttributes(__attributes)
>>              iface.openFeatureForm(layer, temp_feature)
>>              print temp_feature.attributes()
>>         My "problems" are:
>>         In 2.2, after I edit the feature form and press the OK button, the
>>         temp_feature attributes are updated, but so is the first (already
>>         commited) feature of my layer...weird.
>>         In 2.4, the Feature Form always open in non editng mode, even
>>         when the
>>         current layer is editable.
>>         In master (2.5 1b205be), after pressing the feature form ok
>>         button, a
>>         new feature is automaticly added to the attribute table, and the
>>         temporary feature attributes are not updated.
>>         I though it might be something to do with *updateFeatureOnly*
>>         boolean
>>         value, but setting it to True does not seems to make any
>> difference.
>>         Can anyone of you QGIS developing masters throw some light into
>>         my poor
>>         brain?
>>         Thanks,
>>         Alexandre Neto
>>         _________________________________________________
>>     __________ Information from ESET Mail Security, version of virus
>>     signature database 10290 (20140821) __________
>>     The message was checked by ESET Mail Security.
>>     http://www.eset.com
>>     Qgis-developer mailing list
>>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org
>>     http://lists.osgeo.org/__mailman/listinfo/qgis-__developer
>>     <http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> __________ Information from ESET Mail Security, version of virus signature
> http://www.eset.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140821/5d3eaae4/attachment-0001.html>
