[Qgis-developer] Processing causes major slowness at QGIS startup
Andrea Peri aperi2007 at gmail.com
Wed Aug 27 00:05:48 PDT 2014
Hi.
Perhaps this is due to the plugin onstaller serring "alway update at
startup" ?
Il 27/ago/2014 06:35 "Nathan Woodrow" <madmanwoo at gmail.com> ha scritto:
> It should also be possible to add some timing stats to the plugin loading
> code from the QGIS side to log which plugins are taking time to load.
> - Nathan
> On Wed, Aug 27, 2014 at 2:29 PM, Luca Manganelli <luca76 at gmail.com> wrote:
>> On Tue, Aug 26, 2014 at 5:36 PM, Régis Haubourg
>> <regis.haubourg at eau-adour-garonne.fr> wrote:
>> > Hi,
>> > interesting issue.
>> > More generaly, startup speed starts to be an issue here, and plugins
>> take
>> > more than half the time of global startup.
>> Right. If we remove all of those plugin, QGIS is much faster to start.
>> > Do we have tips for plugin authors to speed up python loading?
>> Yes, they should move the big code from init() to initGUI().
>> They should remember that the code in init() is ALWAYS executed, even
>> with that plugin "disabled" from the list.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140827/77dc7a78/attachment-0001.html>
