[Qgis-developer] qgis server can't enable logging
Uros Preloznik uros00 at gmail.com
Thu Aug 28 03:47:01 PDT 2014
Thanks Alessandro,  this is working now. I was trying only with SetEnv. I
also had to set QGIS_SERVER_LOG_LEVEL, otherwise the file was empty. So
this is my setting now which is working (Apache+Fcgid):
FcgidInitialEnv QGIS_SERVER_LOG_FILE /var/tmp/qgislog.txt
FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
LogLevel 0 means that everything is logged, for debugging only.
Is someone working on documentation? This could be included for others.
regards,
Uros
2014-08-27 8:46 GMT+02:00 Alessandro Pasotti <apasotti at gmail.com>:
2014-08-26 23:19 GMT+02:00 Uros Preloznik <uros00 at gmail.com>:
> > Hi,
> > I know this was already discused, but I still cannot enable logging for
> qgis
> > server. My configuration is this:
> > -Ubuntu 12.04
> > -Apache 2.22
> > -Qgis 2.4 (standard install)
> > I added this line to apache configuration:
> > SetEnv QGIS_SERVER_LOG_FILE /var/log/qgislog.txt
> > Nothing happens, I also manualy created empty file and set chown as
> wwwdata,
> > but still nothing is logged.
> > Am i missing something? Any ideas?
> If you are on apache and mod_fcgid you'd better try with
> http://httpd.apache.org/mod_fcgid/mod/mod_fcgid.html#fcgidinitialenv
> Alessandro Pasotti
> w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140828/81b44f49/attachment.html>
