[Qgis-developer] QEP: QGIS Mapserver Python Plugins
Andrea Peri aperi2007 at gmail.com
Fri Aug 29 02:41:38 PDT 2014
I guess the main goal is to avoid that the adopt of python on server
could slow it.
Infact , the main difference from a desktop and a server is that the
first is serving only one perosn and this mean that the user could
wait also for a work for himself.
Instead a server is used from many users and every of them dont like
to wait too much.
So the preferrable is if the python server solution sill be optional.
So who don't need it could to not compile it.
Sincerelly I don t see any advantage in the python server side inside the qgis.
The only scenario I could admit is for a rapid prototype of some
solution, but afer, this
for an usage in a production environment the python solution should be
transform in a C/C++ solution to have the sufficient
execution rapidity.
A.
2014-08-29 10:42 GMT+02:00 Alessandro Pasotti <apasotti at gmail.com>:
> 2014-08-29 10:24 GMT+02:00 Pirmin Kalberer <pi_ml at sourcepole.com>:
>> Hi Alessandro,
>> Am Donnerstag, 28. August 2014, 14.49:47 schrieb Alessandro Pasotti:
>>> as anticipated to some of you during the last HF, I've started to add
>>> Python plugins support for the server side.
>>> The rationale behind server plugins is doublefold: first they could
>>> provide additional services without the need to touch the C++
>>> codebase, second they allow for GUI-based configuration since the
>>> server plugins are not separated from the desktop plugins (of course
>>> the environment and permissions should be carefully configured to
>>> allow information sharing from the desktop user to the webserver user
>> This looks like the first real case for an RFC! I'm quite sceptical adding
>> Python to QGIS server. In my opinion this should be discussed thoroughly first.
> Hello Pirmin,
> thanks for the feedback!!!  At least this is the start of a discussion
> :) I knew from previous conversations with some of you that adding
> python plugins to the server was not at the top of the priority list
> and
> I added QEP (RFC) in the original subject because I know this topic
> must be discussed: I'm not going to do a PR anytime soon, and my
> implementation is more like an hack to see how far can I go with this
> idea, but, so far, it seems quite promising.
> Everybody knows how has been important to have Python plugins on the
> desktop side, coding in Python is 5 to 10 times faster than building
> C++ code and moreover the lower barrier to start being productive will
> bring a lot of new functionalities from a larger pool of developers.
> Last but not least, python plugins do not need to pass the
> PR/pull/build/relase cycle that affect the C++ core, which adds a
> considerable delay to bug fixes and new features.
> That said, I would really like to hear more from you all about the
> reasons to be against this idea.
> Alessandro Pasotti
> w3:   www.itopen.it
> Qgis-developer mailing list
Andrea Peri
qwerty àèìòù
