[Qgis-developer] Questions about Dialog for Select by Expression
Nathan Woodrow madmanwoo at gmail.com
Mon Dec 1 15:10:34 PST 2014
Hey Lene and Junior,
> The height of the expression frame should indeed have a minimum value, to
avoid closing it. But this is not a new behaviour. In QGIS 2.4, you could
already close totally this frame if you drag down enough. I think it's a
bug and you can fill a ticket unless it's an intended behaviour (and it
would be nice if the dev can explain why such choice - thanks).
This isn't a issue anymore as the dialog has been redone in 2.8.  You can
see what it looks like in this
https://twitter.com/madmanwoo/status/539263306716811264
>> Secondly – before there was a syntax coloring – now it´s all the same
color.
We have changed to use a better code editor for the text box and are using
a built-in SQL lexer for the syntax. In SQL single and double quotes at the
same thing, at least the lexer likes to think so.  I'm looking into a fix
for 2.8
- Nathan
On Mon Dec 01 2014 at 9:30:24 PM Junior Delaz <delazj at gmail.com> wrote:
> Hi All
> Lene,
> About syntax coloring, I have it work as expected here but I'm on 2.6.1
> (haven't tried 2.6.0). Maybe, it's already fixed or it's an OS issue (I'm
> on Windows 7  64bits, Osgeo4w advanced install).
> For the last one, I agree with you, we should have kept "load unique
> values" and "All" instead of "load  values" and "All unique". The first one
> seems more comprehensive to me and everybody gets that the "unique" term
> applies for "All" and "10 samples". It may be confusing now, having
> "unique" only on "All" button. No?
> 2014-11-30 9:30 GMT+01:00 Lene Fischer <lfi at ign.ku.dk>:
>>  Hi,
>> In the dialog Select by expression there has been some changes in 2.6
>> Window dragging in expressions must have a minimum vale so the express
>> doesn’t disappear if you drag down.
>> color.
>> At last – why does buttons change name – if there is no change in
>> function? Here I refere to Load values.
>> Please see the video http://screencast.com/t/VE4PvkT1 that explains the
>> questions.
>> Regards
>> *Lene Fischer*
>> Associate Professor
>> *Department of Geosciences and Natural Resource Management*
>> University of Copenhagen
>> MOB +45 40115084
>> lfi at ign.ku.dk
>> [image: SCIENCE_bomaerke_UK]
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141201/c8fa53d8/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141201/c8fa53d8/attachment-0001.jpg>
